911munKy said:Did the track rod come with 2 boots? If so they are slightly different.
It was almost a year ago (and I've had a few of beers tonight) when I changed mine but i vaguely remember having an issue with the boot not fitting so I removed it and fitted the other boot that had a larger diameter opening.
Failing that use washing up liquid around the boot to help ease it on and use a jubilee clip to fix it rather than the fiddly supplied fittings.
wasz said:see here, TRW boots
they do 48 and 52mm diameter
https://www.buycarparts.co.uk/porsche/911-996/8696/10301/bellow-seals
