996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
Tycho
1995 Porsche 993 Carrera 2
PostPosted: Tue Aug 15, 2017 6:26 pm    Post subject: Am I missing something? Reply with quote
I took my spare wheel out for the first time (had to get to a flat battery) and noticed that there were 2 round holes on the floor pan up front. Should these have some sort of bung in them? I blocked them with closed ferrules then wondered if they were meant to left open.
I have done some searching without real success, any suggestions gratefully received.
Shanghai
PostPosted: Tue Aug 15, 2017 6:42 pm    Post subject: Reply with quote
Yes there are rubber drain plugs which fit. From memory there are more than two. They purtrude under the car and often get ripped off. Most cars seem to have them missing. The part number is hard to find as the part is the same as used in the headlights so you have to search for it in that area.
My journal had pics of the part number but they no longer show up.
"Imagination is more important than knowledge" Einstein
2014 Porsche Boxster GTS My Journal
PostPosted: Tue Aug 15, 2017 6:58 pm    Post subject: Reply with quote
I think there's 4 overall. Bad form if your teats aren't showing out underneath what
Allan E
PostPosted: Tue Aug 15, 2017 7:08 pm    Post subject: Drain tubes Reply with quote
These are the little buggers, they fit the boot floor, front and rear lights, available from Type911 at £2 each plus vat and delivery. I would not mind betting they are competitively priced at OPC.
 Filesize:  16.3 KB
 Viewed:  2943 Time(s)
Tycho
PostPosted: Tue Aug 15, 2017 7:38 pm    Post subject: Reply with quote
Thanks Chaps. Looks like a excuse to visit the OPC.
PostPosted: Tue Aug 15, 2017 9:18 pm    Post subject: Reply with quote
Hand What about the plastic nut covers that fit over the metal nuts under the rear spoiler Dont know Classic Illuminati check-list item along with wiper widget and rubber 'bung' to cover the screw in the mirrors Rolling Eyes
All available at OPC
Tycho
PostPosted: Tue Aug 15, 2017 10:11 pm    Post subject: Reply with quote
Nut covers all in place (missing ones fitted recently) just looks like my teats are the problem - add your own punchline.
decgraham
PostPosted: Wed Aug 16, 2017 7:28 am    Post subject: Reply with quote
Part No is 911 631 259 02
ATB Smile
kerb scraper
1997 Porsche 993 Carrera 4
PostPosted: Thu Aug 17, 2017 12:49 pm    Post subject: Reply with quote
If the boot floor drains were scraped off it is likely the little wedge shaped drains for the headlamp pod breathers were also damaged. Part # 993.631.141.01 and you need two at £2.13p
Pursueing the anatomical analogy I suppose you could say these are the ureters.
1997 C4 Cabriolet, Arctic Silver, black interior, 18" hollow spokes, Bilstein PSS10s, RSRs, 200 cell cats, Mobil 1 sticker, LED to interior. Bergville t-lights.
Les Richards
PostPosted: Thu Aug 17, 2017 1:57 pm    Post subject: Drains (or teats, if you prefer). Reply with quote
I believe they are the same as used in the IB models to stop condensation in the headlights.
Les Richards
993
Polar Silver
5152 MU
Tycho
PostPosted: Thu Aug 17, 2017 6:25 pm    Post subject: Reply with quote
Looks like I might have another trip to the OPC Parts Dept. Another way to spend my time now I have just managed to retire.
Tycho
PostPosted: Fri Aug 25, 2017 8:27 pm    Post subject: Reply with quote
Teats fitted, now what is the best way to check if my headlamp pod breathers are OK?
Of course, I took advantage of the trip to Leeds OPC to have a look at their stock. In addition to the new shiny stuff (this did include a 918) they had some serious classics taking up a good third of the showroom. There were a pair of interesting mint green WB 993s
kerb scraper
PostPosted: Sat Aug 26, 2017 12:54 pm    Post subject: Reply with quote
Whilst she is not looking, borrow the wife's yoga mat and lie it down in front of your 993. Lay on the mat with your head in front of one of the wheels and look carefully at the outer section of the lower part of the PU. Just in front of a recessed self tapping bolt head you will see either a rectangular hole, a badly scraped black wedge or a pristine breather outlet. Looking through the adjacent vented part of the PU use a torch to check if the polythene breather tube is present and attached at both ends.
Unfortunately to get at the tube if necessary you'll need to at least partially remove the wheelarch liner. Be warned this is how the slippery slope is entered. You may be drawn into PU removal, repainting and replacement of many missing or rusted parts. But that is a good thing! Smile
Tycho
PostPosted: Sat Aug 26, 2017 5:07 pm    Post subject: Reply with quote
Thanks for the info. No yoga mat – borrowed a (clean) dog towel. Yes, they are missing and no sign of breather tubes. I guess that this results in permanent Illuminati exclusion.
Are these really vital for a car kept in a heated garage & that sees about as much rain as the Atacama)? Any idea what the part no. is for the tubes & what access I need to fit them.
Looks like I have more work to keep me out to mischief and another trip to the OPC.
Shanghai
PostPosted: Sun Aug 27, 2017 11:54 am    Post subject: Reply with quote
Hand its not the rain you should worry about with a 993, its the constant washing Thumb
Tycho
PostPosted: Sun Aug 27, 2017 12:51 pm    Post subject: Reply with quote
Washing currently infrequent – insufficient use! OCD kicking in as I have not had the wheels off for cleaning this year due to hand surgery. Planning a nice early run to the East coast next week with a wash afterwards. Then its service & MOT time the following week.
