997 : 2004- 76
996 : 1997-2005 48
964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
912-914-924-928-944-968 3
jboy
PostPosted: Fri Aug 11, 2017 7:51 pm    Post subject: Reply with quote
Is it the case that having any work done could actually cause more problems than it solves or is that never going to be the case so the worst case scenario is that you have spent money you perhaps didn't need to rather than you have hastened the demise of your car? I'm assuming the IMS replacement is a recognised one...
kas750
Estoril
2006 Porsche 911
PostPosted: Fri Aug 11, 2017 8:07 pm    Post subject: Reply with quote
Changing the IMS bearing is a risky business and there is one poster on here that had a catastrophic failure after a precautionary IMS change.
alex yates
PostPosted: Fri Aug 11, 2017 9:35 pm    Post subject: Reply with quote
Not only is there high risk of not installing the bearing correctly in the shaft (I'm a Toolmaker and have witnessed many kack-handed bearings pressed in at an angle by folk who don't know what they're doing), but also the chance of breaking chain guides and chains jumping a tooth and throwing the cam timing out.
Replacing an ims bearing in situ is not only unprofessional but usually executed by outfits who harp on that they only carry out work to Porche's standard operating procedures. Porsche will never ever change a bearing in situ. These shysters who yank bearings are full of no.2s and only promote swapping bearings to fleece money from weak-minded 911 owners .
Sun's out Gun's out.
jboy
PostPosted: Fri Aug 11, 2017 9:46 pm    Post subject: Reply with quote
Ok thanks - that is interesting. My c2 is on 59k and probably due a new clutch in the next 12 months so the IMS is something I am considering understandably......
alex yates
PostPosted: Fri Aug 11, 2017 9:48 pm    Post subject: Reply with quote
Have it checked out and have outer seal removed. If there's a problem, get on here for advice.
Simon W
1997 Porsche 993 Carrera 2S
PostPosted: Sat Aug 12, 2017 6:22 am    Post subject: Reply with quote
This is what I love about this forum....!
An astounding breadth of knowledge and plenty of healthy debate!
Thank you to all who've contributed - given me a lot to think about!
Suddenly, I'm not so bothered about the IMS, but have turned my anxiety to the bore scoring!
Any simple tell tale signs to look for...?
On the 993's, they were so relatively simple to examine that I could tell very quickly whether a car was a good'un or not. With the 996's, it seems much more tricky, with the sense (probably wrongly) that there could be this hidden time bomb hidden deep inside.....
...is it really such a roll of the dice to buy a 95k motor...? I wouldn't think twice about it on the 993 - but I'm sensing potential big bills due to mileage on the 996. Is that unjustified?
993 C2s Black/Marble (sold)
993 C2s Zenith / Marble (sold)
993 C2s Ocean / Marble (sold)
Simon W
PostPosted: Sat Aug 12, 2017 6:43 am    Post subject: Reply with quote
...and by the way - it's this one....
I'm going to have a look later today.
Thoughts / comments welcome...
https://www.pistonheads.com/classifieds/used-cars/porsche/911-carrera-996/porsche-911-996-carrera-4s-2003/7562154
segart
PostPosted: Sat Aug 12, 2017 6:58 am    Post subject: Reply with quote
As Clint Eastwood might have said, 'the question is, do you feel lucky'? If you are the type who would rather not walk under a ladder, or get involved in breaking a mirror, then all sorts of arguably more sensible sports cars are out there. On the other hand, life is short and we are a long time dead!
Rick
996 C4S Manual
Mini Cooper R56
VW Tiguan Escape
Triumph 955i Sprint ST
PostPosted: Sat Aug 12, 2017 7:00 am    Post subject: Reply with quote
In the current market that seems like a really good car for the money.
Sadly buying any 996 Carrera is a bit of a lottery but look at how much car you're getting for under £20k compared to what a similar mileage/spec 993 would cost you.
If the car passes every check you can realistically put it through I'd go for it and enjoy driving it. IF in the future the worst happened (a £10k bill for an engine rebuild) it would still represent great value-for-money motoring and bizarrely the car would probably be more desirable to any future buyer.
alex yates
PostPosted: Sat Aug 12, 2017 7:22 am    Post subject: Reply with quote
They're a fantastic and reliable motor and the best value for money sports car on the market. If your gonna buy one, condition is priority over age and mileage. If it's got a decent full history, looks right and the bores aren't scored, then you're fine.
A quick 15 minute search session on this website soon highlights that there's more gen 1 997s with bore-scoring and ims bearing failures than 996s. I've visited Hartech on a couple of occasions and seeing the amount of 997s racked up for engine rebuilds soon highlights the fact of how more robust the 996 is. It put me off wanting a gen 1 997.
On a slightly other note, a gen 1 997 with Hartech rebuild can be bagged (if you're lucky) for 996 C4S money.
Griffter
PostPosted: Sat Aug 12, 2017 7:24 am    Post subject: Reply with quote
As stated above, there is a risk in replacing the bearing in situ of:
(A) the bearing not being located properly. Microns out on installation could cause premature failure in due course
(B) causing damage to other components when forces are exerted on them to remove/install the bearing, in directions and in ways they are not designed to withstand
I debated long and hard after buying my 996, and decided on balance to leave well enough alone. The risk of replacing a good bearing seems to outweigh any benefits. Of course if you know your existing bearing is knackered it's a different proposition.
As an aside I though the LN bearing was lived at 4 years/40k miles, so that's all they're guaranteeing it's good for. Strictly it becomes a service item.
Also as an aside, I agree the dual row bearings have been known to fail, but I thought they were obsolete after 98?
alex yates
PostPosted: Sat Aug 12, 2017 7:26 am    Post subject: Reply with quote
Dual row became obsolete after the 3.4 gen ended, 3.6 were single row circa. 2001.
askgeez
PostPosted: Sat Aug 12, 2017 7:29 am    Post subject: Reply with quote
That looks like a great example Thumb
Decent wedge of history would give me some comfort that's it's been looked after. Clutch done at a respected Indy... Who potentially would have felt IMS?
£18k for a manual 4s looks good value...not going down much from there.
My mate bought same model on an 05 plate in April 2015. Absolutely mint ... 25k miles.
Few months into ownership...IMS let go... £8k bill.frustrated
So mileage and condition is no guarantee . But I agree with Terry, drive and enjoy
997.2 GTS coupe PDK
997.1 C4s coupe Manual (sold)
alex yates
PostPosted: Sat Aug 12, 2017 7:37 am    Post subject: Reply with quote
Just looked at that C4S - looks great to me and a well written ad - says a lot about the seller Thumb
Tell tail signs for bore scoring (nearly always rh block) are left sooty tail pipe and rattle from engine. Try doing some youtube searches on bore scoring for examples.
Do not agree to purchase without having a bore scope. If you've half an idea of what to look for in a car and it looks right, personally I wouldn't bother with a ppi.
Bore scope, bore scope, bore scope.
alex yates
PostPosted: Sat Aug 12, 2017 7:55 am    Post subject: Reply with quote
Peter Morgan sums it up here:
a gen 1 3.8 997, but you get the jist. Make sure you read the description.
Open Youtube Page
alex yates
PostPosted: Sat Aug 12, 2017 8:22 am    Post subject: Reply with quote
Just having a browse of the MOT history on that C4S (which all looks fine). There's some absolute muppets about who aren't even fit to own a car. Failed it's MOT back in 2009 due to this:
Nearside Rear Tyre(s) incorrect because different size tyres are fitted on the same axle. (4.1.A.1a)
Duh
paul987
PostPosted: Sat Aug 12, 2017 9:09 am    Post subject: Reply with quote
I'm with Alex on this one.. any failures I've heard of recently have been on engines that's had the IMS replaced!
Most of factory IMS that did let go in the past (including mine) happened at low mileage...
Which is why my money would always go on well used, well maintained 996 over a low mileage garage Queen.
For piece of mind the current consensus is to remove the outer dust shield at the next clutch change.. as recommended by Hartech.
As for some Indy's finding bits of metal in oil filters thus requiring a IMS change... I personally would want to see the IMS in situe first before I made any decision.... Imho. It's a great way for some less than honest indy's to play on people's fears and make some extra cash Thumb
"Strong minds discuss ideas average minds discuss events, weak minds discuss people. Strong minded people discuss ideas to solve problems." -Socrates
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
The Lone Ranger
PostPosted: Sat Aug 12, 2017 12:47 pm    Post subject: IMS Reply with quote
Mmm. I have never heard that it is dangerous to change the ims. Never heard of engine failure caused by changing ims, but others allegedly say that they know of it. People are mentioning some Porsche indys are not doing a good job, WHO? We would all like to know who to avoid.
alex yates
PostPosted: Sat Aug 12, 2017 12:51 pm    Post subject: Reply with quote
All Indys that change ims bearings in situ, it's bad practice and it isn't possible to press a bearing in perfectly as the shaft is unsupported at that end and puts strain on chain guides when attempting to press it in.
segart
PostPosted: Sat Aug 12, 2017 1:16 pm    Post subject: Reply with quote
That clip on the bore scored 997 is absolutely horrendous. The c4s at 18000 pounds looks like good value. I notice the car covered 12000 miles in three months in 2015. That could be a record! Service history looks ok but the duff tyre mot failure points to a less than fastidious owner.
Rick
996 C4S Manual
Mini Cooper R56
VW Tiguan Escape
Page 2 of 3
