996 : 1997-2005 40
Boxster : 1997- 13
Cayman : 2005- 10
Macan : 2014- 0
graeme
PostPosted: Fri Aug 11, 2017 8:38 am    Post subject: 997 warm start problem Reply with quote
Hello I have a recently purchased a 997 Carrera 4s (25000m) bought from Porsche hatfield with 2 yr warranty. Having stalled the car a couple of times I noticed that on a warm start the engine cranks very slowly and makes a clattering noise like someone shaking a bag of spanners. It then starts and runs fine and cold starting is also fine. I will take it to a dealer but wondered if anyone had experience of this, as any background information would be useful when approaching the dealership. Many thanks
JP_Turbo
PostPosted: Fri Aug 11, 2017 9:04 am    Post subject: Reply with quote
Sounds like maybe a coil pack. But I am not an expert....
I would have thought the same thing to happen on cold start if a coil pack though Dont know
TTW
2004 Porsche 997 Carrera 2S
PostPosted: Fri Aug 11, 2017 12:06 pm    Post subject: Reply with quote
I have a 997.1 which can be problematic starting when hot, despite consistently starting good when cold and running good at all times. Having done some research online, there appears to be a known HOT START issue caused by a poor main battery to Alternator cable? - The cables themselves are around £80 but fitting seems to vary from 2-4 hours? - Apparently on Automatic its an engine out job, but not on a manual (fortunately mine is Manual).
graeme
PostPosted: Fri Aug 11, 2017 12:10 pm    Post subject: Reply with quote
Mine too!, thanks for that G
graeme
PostPosted: Fri Aug 11, 2017 12:13 pm    Post subject: Reply with quote
Thanks for that, agree with you logic, I think new coil packs were fitted in presale service but will look into it. G
DucatiRob
PostPosted: Fri Aug 11, 2017 7:58 pm    Post subject: Reply with quote
Almost certainly your battery, easy to check if you have a decent multimeter, or possibly the cable to the starter motor which is a common failure.
Mercedes CLK DD
Ducati 996
PostPosted: Fri Aug 11, 2017 8:04 pm    Post subject: Reply with quote
As Rob says .. a slow spin over of the engine is battery or a high resistance cable to the starter which does happen on these .. the concern i have is the bag of spanners noise .. thats not normal .. if possible a sound clip of it please .
Dexterich
PostPosted: Fri Aug 11, 2017 9:48 pm    Post subject: Reply with quote
Absolutely a known problem with the starter/alternator cable, I suffered with this on my early c2s tip. On long runs battery also fails to charge as heat increases the electrical resistance of the cable which has a crimped "Y" connection that seems to be the root cause. Replacement cost not too bad on manuals but as you say is an engine drop on a tip Surprised .
Fortunately I found Zentrum in notts who have an in situ repair for around £200 - cable will probably need replacing eventually but since I had this done it's been perfect thumbsup
C2S, Black, Tiptronic
monster
PostPosted: Sat Aug 12, 2017 12:40 am    Post subject: Reply with quote
And if its not the starter cable - its likely to be the actual starter motor!
I know the 'bag of spanners' noise you mean - its like a real heavy duty 'pinking' sound - i don't think its anything to worry about - mine did it when i had this problem - i changed the starter cable first that improved it a little, then i caged the starter motor and that really sorted it - turns over now hot or cold real fast!
TTW
PostPosted: Tue Aug 15, 2017 1:27 pm    Post subject: Reply with quote
Battery/Starter cable diagram. (997.1) - The cable is different for manual & tip vehicles.
http://www.design911.co.uk/fu/pt259_261_-cma81-cmo117/Porsche/997-MKI--911--2005--08/Batteries-and-Chargers/
 Filesize:  50.95 KB
 Viewed:  1633 Time(s)
