997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
sim996
PostPosted: Mon Feb 18, 2019 9:26 pm    Post subject: Reply with quote
Got my toe arms made up. Just so happens I've got a precision engineering shop at the end of my Street, he makes parts for noble and Ultima who are both fairly local, so result, ok for £30, I'll get the battery out and see if I can zinc plate them. Just waiting for the lock nuts.
 Filesize:  315.15 KB
 Viewed:  2529 Time(s)
 Filesize:  359.09 KB
sim996
PostPosted: Mon Feb 18, 2019 10:50 pm    Post subject: Reply with quote
GT2 embellishments, I know it's not a proper one. But. Well it's my car and I like it! Handbrake was an eBay bargain at £30!
 Filesize:  531.33 KB
 Viewed:  2490 Time(s)
 Filesize:  460.81 KB
 Filesize:  286.6 KB
 Filesize:  417.43 KB
 Filesize:  417.15 KB
Marky911
PostPosted: Mon Feb 18, 2019 11:22 pm    Post subject: Reply with quote
Blimey your fleet consists of most cars and bikes I’ve lusted after at some point in the last 20 years. Cool
Adjustable toe links are my next job. Dreading getting the boots over those inner rose joints though.
Nice progress anyway. Not sure on the GT2 badging but like you say it’s your car...
sim996
PostPosted: Tue Feb 19, 2019 2:33 pm    Post subject: Reply with quote
They were really easy to fit. I pushed the thin end of the rose joint through the side of the boot, the pushed it through where it sticks out, then just pulled it over the rounded end of the rose joint. It's super stretchy! Took less than a minute. Warm it on the radiator if it feels stiff.
PostPosted: Tue Feb 19, 2019 8:44 pm    Post subject: Reply with quote
Great work worship
PS You can't have a GT2 on GT3 wheels Sad
Marky911
PostPosted: Tue Feb 19, 2019 9:05 pm    Post subject: Reply with quote
Oh right. That’s good to hear. I’ve only read of them being a ***** up until now.
Are yours the McGill Motorsport ones? If not could you post a link to where yours came from.
Good tip on warming them up. That’s exactly what I was going to do. Probably steep them in a sink of hot water for a while before fitting, or like you say, radiator.
Thanks. Thumb
PS. Trust you to mention the wheels, Jin. Grin
The later GT2s used those wheels though did they not? 996 GT2 facelift.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Feb 19, 2019 9:11 pm    Post subject: Reply with quote
They are really easy to fit with the right tool.
http://911uk.com/viewtopic.php?t=125503&postdays=0&postorder=asc&start=300
Marky911
PostPosted: Tue Feb 19, 2019 9:22 pm    Post subject: Reply with quote
Hi Martin,
yes I read that when you did yours. Isn’t the tool £50+ though?
Not worth it to me as I’ll use it once. Well, twice then. Once for each side. Wink
MisterCorn
PostPosted: Tue Feb 19, 2019 9:25 pm    Post subject: Reply with quote
Marky911 wrote:
Hi Martin,
I picked mine up for peanuts, but it was probably 20 years ago.
Marky911
PostPosted: Tue Feb 19, 2019 9:35 pm    Post subject: Reply with quote
Ah well. Good purchase.
I’m tight and I hate clutter, so I’m not a massive tool fiend. I usually just scrounge off my dad. He might have some actually...
sim996
PostPosted: Tue Feb 19, 2019 11:15 pm    Post subject: Reply with quote
HSC911 wrote:
Great work worship
Aye, but genuine GT2 wheels are hens teeth and I've been looking for ages. The front wheel is the same, I just need the dish on the back, besides, I shouldn't have a sunroof either, or Bose door cards, or 997 GT3 seats or rear seats, but I want to take the kids out in it.
What I might do is get some replica rears so I have the correct offset and dish, that should complete the look from the outside, I've already made enquiries with Paul French who can get them.
19" black 997 wheels are up for sale.
A pic of genuine 996.2 GT2 wheels which is the look I'm after, emulated by the same GT3 wheels, except the dished rear which is also wider.
 Filesize:  35.25 KB
 Viewed:  2168 Time(s)
sim996
PostPosted: Wed Feb 20, 2019 11:00 pm    Post subject: Reply with quote
So I did a bit of home galvanising for my toe arms, but it came out black, not that I'm too bothered, maybe my zinc needs changing or I used too much volts, had good results in the past though. Used Epsom salts, vinegar and a car battery.
Got the toe arms fitted. All wheels are fully studded, 68mm front, 90mm in the rear for the bigger spacers needed for GT3 wheels. Giro discs at some point, but these discs will do for now.
 Filesize:  461.48 KB
 Viewed:  2225 Time(s)
 Filesize:  403.9 KB
 Filesize:  473.09 KB
sim996
PostPosted: Wed Feb 20, 2019 11:09 pm    Post subject: Reply with quote
Bumper all fitted, active aero should work and all ducted correctly. Blimmin low though, hope it will go on the transporter ok!
Unfortunately I need to get the bumper resprayed after the hurricane sent it skidding across my stone drive. Lights also need a good refurb, but I can do all the cosmetic stuff later.
I've also got a new number plate for it, which I need to transfer.
 Filesize:  593.15 KB
 Viewed:  2216 Time(s)
 Filesize:  384.47 KB
 Filesize:  272.17 KB
sim996
PostPosted: Tue Feb 26, 2019 3:50 pm    Post subject: Reply with quote
So off it goes to Fearnsport for the final build! SRM fuel system and gearbox to go in.
 Filesize:  396.99 KB
 Viewed:  2090 Time(s)
 Filesize:  354.7 KB
 Filesize:  499.42 KB
sim996
PostPosted: Tue Feb 26, 2019 3:52 pm    Post subject: Reply with quote
Engine is literally ready to drop in!
 Filesize:  357.9 KB
 Viewed:  2089 Time(s)
ragpicker
Reims
PostPosted: Tue Feb 26, 2019 8:19 pm    Post subject: Reply with quote
Great work!
It looks like a barn find though Grin
sim996
PostPosted: Wed Feb 27, 2019 5:13 pm    Post subject: Reply with quote
ragpicker wrote:
Great work!
Aye, needs a damn good clean, I'll get it cosmetically finished once the mechanicals are done.
sim996
PostPosted: Sat Apr 20, 2019 9:04 pm    Post subject: Reply with quote
Found myself back in the UK, so took a trip down to Fearnsport. Gearbox now attached, was waiting for the oil cooler, but that's here now. Won't be long till mapping!
I'll be using the cooler without the bypass, so oil gearbox will warm quicker. It just means it'll take longer to get heat into the cabin. However, gearbox and engine should maintain an even temperature. I'm measuring the gearbox oil temp on the syvecs, sensor is already there. You can see the gearbox oil pump fitted, the cooler connects directly to it.
 Filesize:  496.38 KB
 Viewed:  1642 Time(s)
 Filesize:  528.48 KB
 Filesize:  468.6 KB
 Filesize:  491.38 KB
sim996
PostPosted: Sat Apr 20, 2019 9:21 pm    Post subject: Reply with quote
Fuel system and engine next. SRM hanger with a variable speed brushless pump.
 Filesize:  375.76 KB
 Viewed:  1637 Time(s)
MisterCorn
PostPosted: Sat Apr 20, 2019 9:29 pm    Post subject: Reply with quote
Good stuff. Parked up next to my turbo I see.
Goto page Previous  1, 2, 3, 4, 5  Next
Page 3 of 5
