997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
DJones
PostPosted: Sat Aug 19, 2017 8:53 am    Post subject: Reply with quote
Matt is a good lad, did the clutch and map tweaked on mine. Really happy with it, must get over to see him..
Darren
2002 996 GT2 recreation in Nogaro blue
2017 Ferrari 488 GTB Nero black
2006 Ford GT40 Gulf Racing colours
1994 AC Cobra 427 Guardsman blue
sim996
PostPosted: Mon Nov 13, 2017 8:43 pm    Post subject: Reply with quote
Cracking on! Had no notch the liners as the stroke was fouling. Was a while waiting for the chain tensioners.
Had to cut a new breaker reservoir, the old was broken.
Turbos are a bit of an issue, but will overcome I think! Basically i bought the wrong ones!
 Filesize:  209.12 KB
 Viewed:  3170 Time(s)
 Filesize:  261.3 KB
sim996
PostPosted: Mon Nov 13, 2017 8:45 pm    Post subject: Reply with quote
Timing the cams
 Filesize:  245.39 KB
 Viewed:  3167 Time(s)
911tom
Watkins Glen
PostPosted: Mon Nov 13, 2017 10:02 pm    Post subject: Reply with quote
It’s really coming on now op. Looking good!
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
sim996
PostPosted: Wed Feb 13, 2019 11:36 pm    Post subject: Reply with quote
Bit of an update, pulled it out the garage and have it a clean down, hasn't seen daylight for about 5 years!
 Filesize:  387.75 KB
 Viewed:  2329 Time(s)
Marky911
PostPosted: Wed Feb 13, 2019 11:57 pm    Post subject: Reply with quote
I think we can all agree, the most important thing about this build has already been covered.
Your green tag is present and correct on the PAS reservoir. Grin
The beards go nuts over that you know.
Seriously though some nice work going on there. You must be dying to get it back. Thumb
sim996
PostPosted: Thu Feb 14, 2019 12:04 am    Post subject: Reply with quote
I changed the suspension for B8's and H&R springs, I saw some corrosion on the strut mounts, just minor surface stuff but I've treated it all.
 Filesize:  450.46 KB
 Viewed:  2327 Time(s)
sim996
PostPosted: Thu Feb 14, 2019 12:06 am    Post subject: Reply with quote
New suspension fitted. Various new screws where required. I'm also 2WD now, so front diff removed along with drive shafts.
 Filesize:  438.33 KB
 Viewed:  2325 Time(s)
sim996
PostPosted: Thu Feb 14, 2019 12:13 am    Post subject: Reply with quote
GT2 spoiler fitted. I didn't want joiners for the longer hoses to the rad, so I looked in the parts catalogue and saw the 997 turbo had longer hoses about the same diameter. Much cheaper than the £300 for the GT2 items, got them for about £25 each.
I also got some 10mm ally spacers made up for the bumper using the gasket as a template.
Finally, I just reused the existing rad brackets and just flipped the top one, fits fine.
 Filesize:  314.49 KB
 Viewed:  2319 Time(s)
 Filesize:  400.7 KB
sim996
PostPosted: Thu Feb 14, 2019 12:23 am    Post subject: Reply with quote
Loads of brackets gone for powder coating. No fancy colours, just black.
 Filesize:  265.24 KB
 Viewed:  2312 Time(s)
 Filesize:  402.53 KB
sim996
PostPosted: Thu Feb 14, 2019 12:25 am    Post subject: Reply with quote
Top gear, large bore manifolds, look like good quality
Turbos look good too, xona rota, tial Alpha 3076.
 Filesize:  364.58 KB
 Viewed:  2307 Time(s)
 Filesize:  337.07 KB
sim996
PostPosted: Thu Feb 14, 2019 12:29 am    Post subject: Reply with quote
Engine just about built now. Need new dump valves, f pipe and a few other bits. Nothing major though, hard work is done.
Matt's work really is top drawer, he's optimised everything.
 Filesize:  296.43 KB
 Viewed:  2304 Time(s)
 Filesize:  503 KB
 Filesize:  268.3 KB
 Filesize:  343.05 KB
 Filesize:  352.06 KB
sim996
PostPosted: Thu Feb 14, 2019 12:31 am    Post subject: Reply with quote
Think this will be going once I get the Porsche back on the road! Been a great interim car though and I've been happy to take my time with the build
 Filesize:  341.35 KB
 Viewed:  2303 Time(s)
sim996
PostPosted: Thu Feb 14, 2019 12:33 am    Post subject: Reply with quote
Aye, this will be the year it goes back on the road I think! Been saying it for the last 2!
Marky911
PostPosted: Thu Feb 14, 2019 12:55 am    Post subject: Reply with quote
I just have to add cool garage/car port, cool GTR and is that a Honda NC30 too?
Good work on the hoses. I’m all for dodging the Porsche tax on parts where possible.
Cracking job on the whole thing. Thumb
PostPosted: Thu Feb 14, 2019 1:00 am    Post subject: Reply with quote
Better late then never Thumb
sim996
PostPosted: Thu Feb 14, 2019 8:36 am    Post subject: Reply with quote
It's an RGV, but it's getting sold this week, I need the space. Think I'll just be keeping one car and one bike going forward so I've got a 270hp duratec Westfield that will be going this year if anyone is interested. It's a very high spec and blimmin quick. I just hardly get to use it. Done about 500 miles in 4 years.
 Filesize:  333.86 KB
 Viewed:  2220 Time(s)
 Filesize:  440.54 KB
sim996
PostPosted: Thu Feb 14, 2019 8:44 am    Post subject: Reply with quote
Best update with my gearbox choice too! So I was looking 18 months for this as I knew one was out there, a 997 GT2RS G97.88. I don't want straight cut gears as this is a road car. I have straight on the westy and it suits that, but it isn't quiet. So I can't run quite as much torque, but this is a stronger box with better ratios and a diff as standard, with the proper pressurised oiling and cooling system.
 Filesize:  223.47 KB
 Viewed:  2211 Time(s)
 Filesize:  259.87 KB
 Viewed:  2213 Time(s)
coullstar
PostPosted: Thu Feb 14, 2019 10:51 am    Post subject: Reply with quote
Wow, this will be something else once finished. Bet it will sounds awesome.
DynoMike
2003 Porsche 996 Turbo
PostPosted: Thu Feb 14, 2019 7:05 pm    Post subject: Reply with quote
Really stoked that you've decided to see this through OP.
Will see the beast in person on Saturday, all being well Thumb
2003 996 Turbo
Previous toy 1974 Mini 1000
Goto page Previous  1, 2, 3, 4, 5  Next
Page 2 of 5
