997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
sim996
PostPosted: Thu Aug 10, 2017 8:17 pm    Post subject: Fearnsport Turbo build Reply with quote
Got my engine at fearnsport for a rebuild, Matt really knows his stuff I have to say, though I wish I'd gone to him sooner.
New valves
 Filesize:  203.61 KB
 Viewed:  9325 Time(s)
Ported
 Filesize:  83.32 KB
Rebuilt heads
 Filesize:  246.86 KB
Welded coolant fittings
 Filesize:  299.68 KB
Zinc coated pulley
 Filesize:  266.3 KB
Pistons in
 Filesize:  238.91 KB
Open surgery
 Filesize:  227.46 KB
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Thu Aug 10, 2017 8:21 pm    Post subject: Reply with quote
He does seem to. What are you having done?
ragpicker
Reims
PostPosted: Thu Aug 10, 2017 8:47 pm    Post subject: Reply with quote
He does have a good rep!
Couple of chaps on here have had some work done by him, 911tom has had a big build done and is now running mega power and I also thought MC had an engine down there?
I'm having a rebuild done by Sid at Porsche Torque. More for future proofing and reliability than for ridiculous power. Its an interesting time!
sim996
PostPosted: Fri Aug 11, 2017 5:53 am    Post subject: Reply with quote
Engine should make plenty of power. My main concern is the gearbox.
I'll see if I can cap the torque
ok51mon
PostPosted: Fri Aug 11, 2017 6:09 am    Post subject: Reply with quote
All the best with this build , to Matt's credit his work quality and attention to detail is one of the best .
Recently I was taking apart my car and noticed even the cable ties he used were a US brand costing £65 a bag iirc .
I wonder if it possible for an enthusiast to complete an engine build given that time wouldn't be a factor.
FRP
Superb stuff Matt is well respected Thumb
2002 996tt x50 manual in bassat black - 9eXX
MisterCorn
PostPosted: Fri Aug 11, 2017 6:16 am    Post subject: Reply with quote
I have an engine with Matt, it is being rebuilt with a stronger gearbox. I'll post up details when it is finished. Hopefully next year.
911tom
Watkins Glen
PostPosted: Fri Aug 11, 2017 8:02 am    Post subject: Reply with quote
Very Happy Another work of art from Fearnsport. Been through the same process with mine last year. What are you going for OP? Is it just a straight 3.6 build or are you upgrading to 3.8? Have you decided on turbos etc? Do you have a power figure in mind? With regard to gearbox is it manual or tiptronic? You are right it is torque that will upset the drivetrain. If you plan to 'cap' the torque then you will need to consider what turbo's you fit. My turbo's do not come alive unless they are running around 1.4bar. If I wanted to run less power and torque I would be better off with smaller turbos.... Food for thought but you need an end goal and decide what it is you are wanting to achieve out of this.
996 Turbo - Link to my 3.8L turbo build thread
2011 Cayenne
718 Cayman GTS
350Bhp astra van for work, semi-retired from daily duties
2009 Ariel Atom 3 Supercharged SOLD but never forgotten
FRP
PostPosted: Fri Aug 11, 2017 8:22 am    Post subject: Reply with quote
Tom is spot on
What are your end goals as this will and more importantly affect the build. Its about what you want, near instant spool or grunt all the way to over 200mph, style of driving comes into play, road warrior or euro crusing, or track bla bla bla
From experience, my build went from serious to ridiclous very quickly as the turbos were producing so much power, then you get very serious with the £££ drive shafts, strengthen loads of parts, cooling, oils feeds, fuel system, clutch, fabrications, i wont go on as i am now going for a drive,,,cant resist as at home today
Damm you OP, why do i keep reading these great threads on 911uk !!!
Keep the updates coming,,,exciting times
snb993
PostPosted: Fri Aug 11, 2017 9:24 am    Post subject: Reply with quote
Hi OP
I'm a big fan of Matt and his work too having known him since his AMD days: a thorough gent and excellent work - you are definitely in good hands
The 'trouble' with mine is that he did all the work on it back in 2010 and... nothing has played up/broken/gone wrong at all since so i will have to get the latest edition of 'Man maths for Porsche owners' out as i need a winter project puh
(just back from another fab weekend on Bugatti circuit and it turned 71K on the way back - 996T's are fab cars! worship )
Good luck with your build OP
ps. Hi Faried - you met a friend of mine (also called Simon a few months ago in Cockfosters and he says hello Thumb ) sorry for the thread hijack!
996T - Cobalt blue, K24's, GT2 I/C's, Techart SSK, Manthey KWv3, H&R ARB's, RS engine mounts, Europipe, GT3RS 6 pots, 997T discs/RS29's all round etc
964 C4 - GP white, 993 C4 gearbox/front diff, Wayne remap, Bilstein B6's / H&R springs, polybushed, Cup 1's, RS SSK, gutted cat etc
993C4 - sold
928S4 - sold
Diggermeister
PostPosted: Fri Aug 11, 2017 9:45 am    Post subject: Reply with quote
Looks very tasty! A 3.8 re-work has crossed my mind.
I did wonder about installing the GT3 valve train components and con rods to allow a few more revs, but I guess with the turbos, what you gain in power top-end, you;d likely lose because the turbos drop-off?
ok51mon
PostPosted: Fri Aug 11, 2017 9:48 am    Post subject: Reply with quote
FRP wrote:
Tom is spot on
Bring it over !
sim996
PostPosted: Fri Aug 11, 2017 9:26 pm    Post subject: Reply with quote
I saw yours down there, I'm getting the same modified water lines etc, as it's a far more robust solution. Where did you get your gearbox sorted, mines a manual.
It's a road car, so I'm not too bothered about a headline figure, just that it's driveable.
Id cap the torque through mapping, turbos just need to be efficient.
911tom
Watkins Glen
PostPosted: Sat Aug 12, 2017 7:55 pm    Post subject: Reply with quote
My gearbox was rebuilt by a firm in Germany. They only build automatics though... I'd suggest for your car you discuss options with Matt as I am sure he has built or knows where to get it done. Sports and Classic come to mind or as far as I know Bill Radar in the US of A is best known for strengthening these manual boxes. Faried (FRP on here) has just had a manual box built for his 9exx, might be worth a chat with him and 9e.
As far as capping torque with the tune. Obviously that can be done but ultimately not great as a permanent solution. If you spec to bigger turbos they may not get in to their efficiency range. If you do not want to build the gearbox then you will need to spec turbos etc to suit whatever the safe torque level is for the stock manual box. I have no idea what that is as mine is a tip. If you are thinking you will build it but not right away then go for the bigger turbos and get the tuner to write you multiple maps. I can highly recommend Rick at Unicorn Motor Developments. He is the only tuner I am aware of that can run multiple maps on the stock ecu.
2011 Cayenne
718 Cayman GTS
sim996
PostPosted: Sun Aug 13, 2017 12:13 pm    Post subject: Reply with quote
Yes, I'll speak to Matt again regarding the gearbox, he said yours was sent away so figured it wasn't something Matt did. He's explained the limitations with 6th gear and the helical gears, but I've not pressed him for a solution.
I get the feeling strengthening might be outside of my budget, so maybe just a refresh and torque limit the output for safety.
Anyone know a safe limit for the manual box?
FRP
PostPosted: Sun Aug 13, 2017 1:14 pm    Post subject: Reply with quote
Safe limit for a manual box has so many caveats
Hard launch or not
Health of the current box plus history of the current box
What is second and third gear wear and tear like
What will the power curve look like and how will it deliver the power to the box,,,,also remember its loosing traction that can destroy a box too
INMO If your gearbox is in good condition and you DO NOT implement too many hard launches, a manual box has to be good for 660 to 710 bhp but dont quote me
My box is a manual and has hed extensive works plus the drive shafts etc
At a certain power output, you need to consider going 2wd as the front diff cannot take the power!!!
sim996
PostPosted: Sun Aug 13, 2017 4:36 pm    Post subject: Reply with quote
Hard launch or not
I assume you mean torque? If I limit torque to say 650ft/lb that should keep things safe, then run to xxxhp at max revs
It won't be getting launched and won't be tracked. We'll see when it's finally running, won't be till after Xmas though, I'll just get the engine built this year.
MisterCorn
PostPosted: Sun Aug 13, 2017 4:56 pm    Post subject: Reply with quote
Straight cut gear set, billet diff cover, stronger diff, 2wd so the front diff doesn't pop, GT2 oil pump and spray bar, Bob's your uncle.
MisterCorn
PostPosted: Sun Aug 13, 2017 5:15 pm    Post subject: Reply with quote
Pesky double post. Matt is sorting mine out for me so it can be done.
FRP
PostPosted: Sun Aug 13, 2017 5:36 pm    Post subject: Reply with quote
All of the above and more LOL
Goto page 1, 2, 3, 4, 5  Next
Page 1 of 5
