997 : 2004- 69
996 : 1997-2005 50
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 16
Cayman : 2005- 14
Cayenne : 2003- 8
912-914-924-928-944-968 3
mun802
PostPosted: Wed Aug 09, 2017 1:00 pm    Post subject: Retro fitting electric seats Reply with quote
Hi Guys,
Is it possible (easy) to retro fit electric seats in place of my manual ones. Not sure if it helps but they're only electric for height adjustment.
mun802
PostPosted: Thu Aug 10, 2017 1:42 pm    Post subject: Reply with quote
anybody???
mun802
anybody???
demon
PostPosted: Thu Aug 10, 2017 2:43 pm    Post subject: Reply with quote
Unbolt the manual seat and have a feel around under the carpet cut out beneath it....
- you should find that a standard loom and connector (and most likely relays) are all in place, regardless of what seats were originally fitted - this has certainly been the case in each 'modern'(ish) Porsche I've owned (I changed the seats in all of them - you will only likely have issues if you fit seats from a different generation e.g. 997 to 996, but these are far from insurmountable - I have a set of heated 997 sport seats in my own '98 996)
1998 Carrera - Black, manual, MO30/220, polybushed, Girodisc brakes, custom decklid
mun802
PostPosted: Thu Aug 10, 2017 2:57 pm    Post subject: Reply with quote
Excellent , thank you.
