Traction control or lack off
coullstar
Singapore
15 Sep 2015
2,834
I'm back looking at 996s and with current budget im looking at earlier or higher mileage cars. Would love another C4s but that's not going to happen.
Anyway I recently wrote off my 986 Boxster S recently odue to road conditions, diesel and you could argue lack to talent. Now I wasn't mucking around or driving aggressivly so I was surprised a by how quickly it went all wrong and ended up under a truck.
I have to admit this is playing in my mind a bit as I've never had a road crash before in 20+ years of driving. Therefore the question I have is that a lot of the 996 I've seen don't have TC so I'm wondering how they behave in the wet and how progressive they are when the rear does let go? Those with C2's I'm just interested as to how often do you find your TC working on the car.
It wont stop be buying the right car & I know throttle works both ways plus there's loads of other factors but I was really surprised at how quickly it went wrong with the boxster.
I have a '98 C2. I don't have TC, and I've had the car give a proper wiggle in the damp when being a bit of a spanner with the throttle (provoked) on fairly crappy tyres.
I've also provoked it massively by coming in ridiculously hot into a roundabout, prompting plenty of weight transfer and getting that engine mass moving.
Both have been under what one would argue is fair provocation, and I've only ever done it on wide empty roads.
Given that a Boxster is much more benign (until you get *right* to the limit, and then the low polar moment of inertia will bite) and generally much more neutral on the limit and you managed to stuff it, I'd invest in some driver training if you buy a 996.
PSM is supposed to be pretty good, the early 'TC' less so as it's not as intelligent nor able to control the car - PSM has full control of the throttle, independent braking on each wheel and is a pretty sophisticated stability management system. TC cuts the ignition/fuelling (the throttle body is mechanically actuated so it can't feather the throttle) in a fairly abrupt way so is more of a blunt instrument.
The 996 is a very fine handling machine due to the Weissach rear, nice responsive engine, and it has lots of grip. Can't bend the laws of physics though.
It sounds like a narrow bodied C4 would suit you. A bit more peace of mind than a C2 and far cheaper to buy than a C4S.
Personally I think the key word in your problem was 'Diesel'. Once you hit that stuff it can flumax the most sophisticated cars as it turns the tyre traction into teflon.
Terry's got a point though - all 996 C4 cars are fitted with PSM as standard and you also have the peace of mind that you have a basic AWD system and a slightly heavier front end.
I found the Boxster fairly easy to provoke at round abouts etc in the wet if I wanted to, it seemed quite progressive and controllable however in this instance is just snapped without any pushing.
I realise the diesel and wet were major factors, it gave me quite a scare however the car was damn good fun and I'm keen to have something similar.
The 4s was definitely less inclined to breakaway for sure. Thing is I'd like as simple a car as possible to possibly use and learn from so can the TC be turned off if required if I happen to find one with it?
PSM switch is on the dash and can be easily overridden.
I find the boxster unstickable in the dry but very hard to control in the wet if it lets go. With its central weight it spins freely if it breaks traction so I always drive with respect in the wet in it. Anyone who knows me understands I usually drive like a hooligan 99% of the time so for me to show restraint in the boxster proves how snappy they can be. Been bitten several times in the wet on track and on road. Lift off oversteer in the wet can be horrendous in them!
Modern 911's (996 onwards) are FAR more easy to control when they lose grip IMO so I think you would be just fine in a C2 with or without TC. I reckon a lot of the VC's in the C4's/4S's and turbos will have become knackered by now too so you can't be guaranteed that you'll be getting 4wd in one of those.
Alternatively look for a 987 which will come with PSM as standard? :?:
Thanks that's good to hear from someone that has experience. Yeah I'm after another 911, the boxster was ace but really need a 4 seater as I'll have to sell the Corrado so needs to take as many people.
Agree the boxster was brilliant in the dry.
I agree with alex tc/Psm won't save you if you hit something slippery and the tyre have no traction. I've never really noticed tc doing anything other than cut the throttle which can be achieved by lifting your right foot. I had a moment recently in the atom. Was driver error, completely misjudged a corner and ended up facing the wrong direction. No traction control in the atom. Not sure tc would have been able to help much, I was just going too quick.
Come to think of it my turbo now has no traction control, is rwd and over 800hp. Being rwd I find gives a lot more feel and warning than awd. Generally if you have a moment in a awd care it ain't gonna be pretty.
As for you op I think you've just been unlucky that the accident happened but actually very lucky it was not fatal! Sounds like you've had a few quick cars and only one accident in 20 odd years so you are not doing too badly. Did you ever notice the Psm cutting in in your old c4s? How much you relied on that will tell you if you need it or not.
Got bitten VERY hard by my 986 S at Oulton Park many years ago, lost control incredibly quickly on a damp track, lift of oversteer/grass/off camber resulted in a bit of a mess. Had been doing track days for 10 years at that point.
Have an awful lot of respect for the Turbo as a result. :eek:
My C2 was very unpredictable in the wet and unless you drove the like the vicar it could catch you out even at low speeds in the wet at roundabouts or tight bends - and the issue was on michelins it wasn't progressive it was all or nothing when it did go - where as on cheaper tyres i found it always went a bit here and there first so was actually maybe safer as you were expecting it to go!
The 996 is nothing like early "pendulum" 911s
If you feel its unsafe in the wet or whatever then get your geo checked and some new tyres, there is something wrong.
The 996 is the most stable rwd car I've ever had, including much lower powered saloon cars.
So much traction. I've never had tricky situations at road speeds, only on the track when pushing harder than I ever would on the road.
I think your boxster problem was "diesel" as alex says.
I have a 1998 C2 with an LSD. It has traction control which I frequently turn off. I find it a handful on the track, despite having raced single seaters in the past. It's very keen to oversteer on corner entry when driven at 10/10ths. This is related to tired dampers and I'll be sorting it when funds allow.
On the road in the wet it will drift predictably and reliably with the TC turned off. It's not as easy as an MX5 or an M3, but with practice you can drift around roundabouts all day long. I rarely drift it in the dry because it's got so much tyre on the road you have to be going very fast and there is no real room for cockup. It's also much harder on the car.
If you want to drift your 996 you need to dial out as much of the understeer from the suspension as you can, and find a consequence free environment to learn in.
I'm very impressed how much traction my MY99 C2 (LSD & TC) has, even on damp surfaces with old S02's. At road speeds it's never caused me any problems (I'm not a drift king though... :) )
My 986S was a pig on its first trackday, when I discovered it would push in the bends with the slightest throttle. A decent geo (getting the rear wheels pointing the right way..) + new m030 suspension sorted that. I ran it on a square setup (225/45/17) & was very pleased with it as a fill-in track car while I was fixing my broken 944.
I was wary of it to start with but found it very benign - even when it got a bit out of shape on the track it seemed to be better at correcting itself than I was.. :) Seemed to let go fairly slowly as well.
I've always found Porsches very sensitive to geo and tyre pressures & when they are right, the handling is great.
124,588
1,441,799
49,014
mwarren1
