997 : 2004- 74
996 : 1997-2005 42
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Easto
PostPosted: Sat Aug 05, 2017 6:19 pm    Post subject: Filling up - argh! Reply with quote
Does anyone else have an issue filling the car up.
Might just be tesco pimps but holy smoke I called it a day and was only 3/4 full.
Constantly cutting it.
Must be a knack to it I've not fathomed yet!!
Martian
2007 Porsche 997 Turbo
PostPosted: Sat Aug 05, 2017 6:24 pm    Post subject: Re: Filling up - argh! Reply with quote
Easto wrote:
....Might just be tesco pimps....
I find those Tesco pimps a problem at times, try the Shell pimps, they're more accommodating. Very Happy
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Sat Aug 05, 2017 6:25 pm    Post subject: Reply with quote
Mine never has problems with my local Tesco Momentum pumps.
I have had probs with some pumps in the past, my guess is that the flow rate on that particular station/pump is too high, causing it to cut out.
I assume you have tried withdrawing nozzle slightly? Having nozzle upside down (trigger on top)?
James
Manual 997.2 c2 :Basalt + gtechniq
James M-S
PostPosted: Sat Aug 05, 2017 6:27 pm    Post subject: Reply with quote
Double post
stucart
PostPosted: Sat Aug 05, 2017 6:40 pm    Post subject: Reply with quote
http://cdn.shopify.com/s/files/1/0801/3855/products/Pimp-1_grande.jpg?v=1496852335
What your "pimp " look like??
997 C4S Tip-S, 2007, Silver/Red Leather, PSE, Sports Chrono, Turbo wheels.
alex yates
PostPosted: Sat Aug 05, 2017 6:57 pm    Post subject: Reply with quote
If it knocks off, pull the pimp out slightly. Relieves some of the back pressure that knocks it off.
Easto
PostPosted: Sat Aug 05, 2017 7:05 pm    Post subject: Re: Filling up - argh! Reply with quote
Tried all these methods apart from upside down...
shell pimps are finer for sure... Wink but typically you pay for that quality 😀
And it's miles away
Monkeynutz
PostPosted: Sat Aug 05, 2017 7:12 pm    Post subject: Reply with quote
give the nozzle a few solid taps that should work. If not go home and repeat somewhere private it might not get the car filled up but you will feel less stressed afterwards if nothing else Wink
997.2 C4S
James M-S
PostPosted: Sat Aug 05, 2017 7:24 pm    Post subject: Reply with quote
Floor Grin worship
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Sat Aug 05, 2017 7:45 pm    Post subject: Reply with quote
No issues for me on the Shell pimps, I'd start looking at the interface between the pump and the car. Perhaps ask a lady passer by to assist.
Current: 2009 997.2 C2S
Previous: 2008 Cayman 2.7, 2002 Audi TT, 1999 BMW 318!
Shanghai
PostPosted: Sat Aug 05, 2017 11:01 pm    Post subject: Reply with quote
Its your car trying to tell you not to put that nasty supermarket stuff in it Grin Grin like a baby when it doesn't like the food. Go give the poor thing some proper vmax and stop being a tight ass Floor the car will reward you for it a happy car is a fast car and leave Tesco to sell Food. Grin Grin
PS you wont have a problem with pimps if you pay the right money Very Happy Smile
pzero
PostPosted: Sat Aug 05, 2017 11:20 pm    Post subject: Reply with quote
http://911uk.com/viewtopic.php?t=119752&sid=12cf6efc6f1d44670d5ab99c9c9820a1
Some more chat about this issue.
The return of Marty Wild
PostPosted: Sun Aug 06, 2017 5:45 am    Post subject: Reply with quote
My Cayman suffers from this, took a while to get used to it. 90% of my fuel comes from Shell, they even have a new digital button system at my local....
Same issue, I have to cadence tap the max fuel speed button as the slow speed does nothing.
This happens at all pumps no matter what method I utilise. Found some stuff about it on the American Cayman forum.
On normal pumps I just depress the trigger gently and dispense the fuel slowly.
Cayman S 987.1
Les
2008 Porsche 997 Carrera 2
PostPosted: Sun Aug 06, 2017 5:46 am    Post subject: Reply with quote
As long as the pump is upside down you should be fine.
According to Chris Craft, I'm officially the 'Unluckiest 911 owner in the world'.
5 x 911's and 4 catastrophic engine failures. So far so good with Porsche no. 6
Easto
PostPosted: Sun Aug 06, 2017 6:27 am    Post subject: Reply with quote
911TEL
2011 Porsche 997 Turbo S
PostPosted: Sun Aug 06, 2017 8:02 am    Post subject: Reply with quote
Same issue ,on the 911.... everytime , no matter what pimp i use ....!
Im used to it now ....
My Cayman hasnt had this issue though strangely enough
Cayman GT4 Carmine red .. at last it gets the goodies it should have....
997 Gen 2 Turbo S Basalt Black -BBS CHR, Kline inconel exhaust, Polished Bliss air freshener...
SL 55 AMG Obsidian Black
Brompton S2L Black edition
K888ETH
PostPosted: Sun Aug 06, 2017 8:26 am    Post subject: Reply with quote
I have found the pump cutting out issue regardless of the filling station, it seems to be a Porsche thing! My Boxster did it and now my 997, thankfully, it's easily solved by doing the upside down pump trick. Once it does cut off do not be tempted to try adding any more fuel...your shoes will suffer, I found out the hard way! Very Happy
997.1 Turbo
PostPosted: Sun Aug 06, 2017 8:45 am    Post subject: Reply with quote
Upside down trick usually works. A chap who had a Balmoral Green Range Rover gave me that tip Thumb
PeterH
PostPosted: Sun Aug 06, 2017 4:33 pm    Post subject: Reply with quote
I use mainly Tesco and sometimes Shell, never had an issue fills up without ever cutting out must be lucky I guess 😁
997.2 C2s coupe basalt black
911DG
PostPosted: Sun Aug 06, 2017 5:24 pm    Post subject: Reply with quote
LOL that made me chuckle Grin
Now:
- 997 C2S Cab (black on black on black)
Then:
- 996 C2 Cab (Black with Red)
- 996 C4 Cab (blue with grey)
- 993 C4 Cab (Black ith beige)
