I wonder if someone would be kind enough to have a look at their door handle (the internal one in the door card) and answer a couple of questions for me.
Please pull the handle so that you can see the linkage rod where it attaches to the door handle.
Q1. Does the rod slot into the handle from above or below? The PET diagram suggests it should slot in from below.
Q2. The rod sits in a white nylon bearing/clip. Does yours have any form of retainer on the end of the rod? Last time I had mine apart one side had a retainer whereas the other didn't. The retainer is a small cadmium plated metal disc with a hole and slots cut into it which is pushed onto the end of the rod and grips it. The PET diagram doesn't appear to show these retainers .
TIA.
TIA.
