997 : 2004- 72
996 : 1997-2005 42
993 : 1993-1998 11
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 13
Cayenne : 2003- 11
Macan : 2014- 1
912-914-924-928-944-968 6
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Thu Aug 03, 2017 9:06 pm    Post subject: My tail light fell out!!!!! Reply with quote
Fortunately for me it happened as I pulled into my driveway and I heard an odd clunking noise.
On inspection there appears to be a nut and a plastic mounting that have sheared off, some evidence of a previous Araldite repair too.
I see online in the States there is a product called Light Savers.
Has anyone used these?
Any U.K. sources?
Any advice?
Thanks in advance
Marky911
PostPosted: Thu Aug 03, 2017 9:18 pm    Post subject: Reply with quote
Not sure which model yours is Peter? It's more common on Turbo/C4S.
Thread here that might be of interest.
http://911uk.com/viewtopic.php?t=111550
Halcyon
PostPosted: Thu Aug 03, 2017 9:31 pm    Post subject: Reply with quote
there's a chap called Neil Bullett Belton in the 996 facebook group that's just fitted these "light savers" to his UK Turbo.
Worth asking him where he got them from? Thumb
996.2 Carrera 4 Convertible Tip
e92
PostPosted: Thu Aug 03, 2017 9:57 pm    Post subject: Reply with quote
I bought some light savers a year ago. They are decent but depends how broken your lights are. I bought mine from rennfix in America. He sells them on ebay. if you youtube lightsavers you can see what they are.
2001 996 Manual Turbo - Markski Remap, 964 RS LWFW, GT3 gearbox mount, Cargraphic Exhaust, 997 GT2 SSK, Forged DV, PSS10 Coilovers, GT3 front brakes, RSS Engine Mounts, Recaro seats, GT3 front control arms
2008 E92 M3 - Sold
peterzoom
PostPosted: Thu Aug 03, 2017 11:06 pm    Post subject: Reply with quote
Thanks for all the tips and links everyone.
Mine is a narrow body and it is the 10mm captive bolt area that appears to have broken away.
Going to have a proper look at it tomorrow, but initially my thoughts are that the Light Saver is not going to work on this model. The wide body has two screws as opposed to one nut/bolt combo.
So might have to get creative and use my motorcycle fairing repair skills or perhaps buy a new unit.
Tomorrow will tell! Wish me luck
peterzoom
PostPosted: Fri Aug 04, 2017 3:44 pm    Post subject: Reply with quote
Just popped the rear light unit back in after effecting a repair.
On inspection the captive nut and the plastic that captivates it had separated. It had clearly been repaired previously with copious amounts of Araldite or similar.
I scraped and cleared all that would come off from the remaining plastic and there was frighteningly little plastic left.
I located the nut and the remaining plastic with a couple of tacks of Super glue, using some Blu Tack and a cocktail stick through the centre of the nut to give a clear centre line and allow me to hold it square until the glue set.
Next I used a soldering iron and a tie wrap to build up some material about the shoulders of the nut and onto the body of the light unit. I gradually built up several layers of plastic by melting the tie wrap onto the area until it looked securely located.
I picked out the Blu Tack once everything had cooled and trail fitted the retaining bolt to check how secure it felt. All seemed solid, so back over to the car.
Quick clean up of the recess where the unit sits and back in with the repaired light. A few tweaks to the locating bracket to get the perfect fit and it looks and feels fine.
A road test to see if it all holds together, any excuse for a drive!
All good, phew
Now to see if this repair is going to last any decent length of time.
I will update if it falls apart, but otherwise, no news is great news.
Marky911
PostPosted: Fri Aug 04, 2017 8:13 pm    Post subject: Reply with quote
Good work! Fingers crossed it lasts. Plastic weld is surprisingly strong, so no reason why it shouldn't eh. Thumb
Post new topic   Reply to topic   All times are GMT - 11 Hours
