997 : 2004- 76
996 : 1997-2005 48
964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
912-914-924-928-944-968 3
sje00
PostPosted: Tue Aug 01, 2017 5:17 am    Post subject: 996 Carrera 2 Anti Roll bar and bushes upgrade Reply with quote
Hi guys,
Looking to upgrade my Anti roll bars and ARB bushes on my 2000 C2 3.4,
What are the best options?
Looking for Powerflex bushes to match also.
2000 Porsche 911 996 Carrera 2 Aero 3.4
sje00
PostPosted: Tue Aug 08, 2017 11:41 pm    Post subject: Reply with quote
Anybody?
ELA
PostPosted: Wed Aug 09, 2017 5:42 am    Post subject: Reply with quote
Keep the stock ARB's, they are very light hollow design. I think RPM Technik do a replacement set. In fact I've just checked see here
Powerflex bushes are a wise choice, due to the state the OEM rubber ones will be in after all this time.
Before ARB's though I'd upgrade the suspension and see if you still feel the need to swap the ARB's.
CLR996 1086kg bespoke design
thecarfixer
PostPosted: Wed Aug 09, 2017 7:10 am    Post subject: Reply with quote
M030 bars are a good OE upgrade. To get them, you can use a Boxster 3.2S front bar (same size) and then you only need to find the genuine M030 rear bar which is fairly pricey from Porsche - I paid over £100 just for the rear from an independent supplier (in Germany).
Flattens the car out nicely in the corners without adversely affecting it for the road (too much will actually reduce grip on the inside wheel(s) in corners)
ELA
PostPosted: Wed Aug 09, 2017 7:12 am    Post subject: Reply with quote
Good point thecarfixer. I have the M030 ARB's on mine so by stock I was referring to these above.
Paz
1998 Porsche 996 Carrera 2
PostPosted: Wed Aug 09, 2017 6:20 pm    Post subject: Reply with quote
I have my original C2 M030 bars sitting in the garage collecting dust.
If you'd like them and you're happy to collect then let me know, I've been too lazy to list them for sale on here.
I replaced my factory fitted M030 setup with genuine Porsche M030 replacements, fantastic road suspension in my humble opinion, certainly perfect for my type driving - a fast road car that routinely tours the length and breadth of this country.
trig_112
PostPosted: Wed Aug 09, 2017 7:02 pm    Post subject: Reply with quote
If the OP isn't interested in them can you let me know. I'm only near Kettering so not a million miles away.
Garage:
2004 996.2 C2
2008 Alfa Spider
2016 Evoque
1987 Escort RS Turbo
Countless spares and push bikes
Past Porsche: 1983 924
Paz
PostPosted: Thu Aug 10, 2017 9:08 pm    Post subject: Reply with quote
Sure thing trig, I'll keep you posted Thumb
sje00
PostPosted: Sat Aug 12, 2017 6:32 pm    Post subject: Reply with quote
You are welcome to the bars buddy.
The car already has DesignTek Coilovers, ARB's were next logical step for me.
cvega
PostPosted: Thu Aug 24, 2017 1:55 pm    Post subject: Reply with quote
gonna hijack this one real quick, my car already has ohlins road&track but stock bushes, some in sorry state - which powerflex bushing kit works for a 996 c2 (2003) ?
2003 996 C2, Ohlins, other than that stock
2017 Leaf 30kWh
gone:
2010 335d
2007 Cayman S
2008 Civic Type-R
1992 MR2 Turbo
1994 MR2 N/A
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu Aug 24, 2017 2:16 pm    Post subject: Reply with quote
If you are asking about ARB bushes, you will need to measure the thickness of the roll bars and order using that information.
demon
PostPosted: Thu Aug 24, 2017 3:57 pm    Post subject: Reply with quote
Agreed - far more sensible to buy yourself a cheap basic Vernier gauge and work from true diameter of the bar currently on the car - you may then need to make a bit of a 'choice' from the listed Powerflex bush options
FYI - on the pricey end, but you may want to consider the GT3 rear ARB - the same size or slightly thicker(?) than the MO30 option, but with 3-4 holes on the end for additional adjustability...
I fitted mine years ago, so cant remember the exact specs - suspect it is slightly thicker than MO30, which is why I would have used the "softest" hole....
i.e. totally removing understeer or a certain degree of "compliance" between various suspension components is not necessarily desirable(!), particularly on a road (rather than track only) car
1998 Carrera - Black, manual, MO30/220, polybushed, Girodisc brakes, custom decklid
