997 : 2004- 68
996 : 1997-2005 50
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 16
Cayman : 2005- 14
Cayenne : 2003- 8
912-914-924-928-944-968 3
alex yates
PostPosted: Wed Aug 02, 2017 4:00 pm    Post subject: Reply with quote
911munKy wrote:
Just to double check it appears that to reduce NVH it seems like a good idea to cut down the 2 outer plates to the same size as the Outer diameter of the gearbox mount bush to reduce stiffness/vibration transfer and also (not sure here) cut off the top finger part of the insert but still fit it OR cut the webbing section in between the 2 outer parts of the top finger?
Cut the flat webbing section on the top finger to just leave the round outer parts.
Sun's out Gun's out.
911munKy
PostPosted: Wed Aug 02, 2017 7:41 pm    Post subject: Reply with quote
Thanks, mounts now ordered.
2000 C2 996
Locosaki
PostPosted: Wed Aug 02, 2017 7:46 pm    Post subject: Reply with quote
Can anyone post a picture of what should be cut with the poly inserts, I'm not sure what I should be cutting if I try the inserts
Carrera 4 MY99 with full Hartech rebuild
alex yates
PostPosted: Wed Aug 02, 2017 8:09 pm    Post subject: Reply with quote
infrasilver's the man.
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Thu Aug 03, 2017 12:40 am    Post subject: Reply with quote
I have eventually got around to changing the pictures in my 996 thread and you can now see what I did to modify the poly insert.
http://911uk.com/viewtopic.php?t=120681
toobusy
PostPosted: Fri Aug 04, 2017 3:54 pm    Post subject: Reply with quote
I thought this looked an interesting piece of equipment:
https://www.youtube.com/watch?v=jwznwND__zc
Dove House fitted my new mount and it was a "challenge"..
2003 Carrera 4, KTM, Jota
alex yates
PostPosted: Sun Aug 06, 2017 9:08 am    Post subject: Reply with quote
PLEASE READ THIS THREAD IF FITTING THE INSERTS: http://911uk.com/viewtopic.php?p=1332560
Goto page Previous  1, 2
Page 2 of 2
