G50\50 or G50\52 available for sale anywhere in the UK?
Chris_Von_Bron
24 Jul 2017
3
Hi all,
I was wondering if anyone has or knows where a G50/50 may be available for sale?
I'm looking to do a DeLorean LS3 430 HP/428 lb-ft conversion. Although the Renault UN1 gearbox can be strengthened with upgraded parts which include a single input shaft and a Quaife LSD it apparently can take up to around 500HP and 500lb-ft of torque BUT not if the clutch is dumped and other similar abuse is put on it. Although my car will be 90%+ driven on the road I would like to take it to the odd racetrack and drag strip to surprise other enthusiasts as to what a DeLorean can do. I don't want to therefore be wondering if in none road use scenarios as to what it will take for the UN1 to break.
To recap, a DeLorean is rear engined like a 911 so most other gearboxes won't work unless you want 5/6 reverse gears and one forward gear.
Current UN1 369 5 speed gearbox is stock: 3.36:1, 2.06:1, 1.38:1, 1.06:1, 0.82:1
final drive 3:44:1
The strengthening upgrade I 'was' looking to do would also make 1st and 2nd much closer and 5th would be changed to a .70 ratio to drop my revs on the motorway to help with economy and a quieter cockpit.
I've found two Porsche gearbox contenders due to the 5th gear being nearer to around 0.7 that was possible with the upgraded UN1. Also the 6 speed is longer and heavier plus I've learnt that 1st and 2nd syncros are stronger on the 5 speeds.
Space is a real issue with this project as just a 'few extra inches' in new transmission length combined with the extra length of the LS3 engine make it tighter
The two options are
G50/50
G50/52 (by changing the bell housing to that of the G50/50
G50/50
911 (930) Turbo 1989 300 HP 317lb-ft info sourced from https://www.autoevolution.com/cars/...html#aeng_porsche-911-turbo-930-1977-33-turbo
http://www.gboxweb.com/g50specs.html
5-speed fully-synchronized transaxle
Manufactured by Getrag
Plate-type limited-slip differential available
Rod shift
Single-plate clutch
Gear ratios:
1st gear: 3.154
2nd gear: 1.789
3rd gear: 1.269
4th gear: 0.967
5th gear: 0.756
Ring and pinion: 3.44
https://californiamotorsports.net/pages/porsche-g50-5-speed-transaxle-specifications
5th gear 0.767
Weight: approx 156lbs (71KG)
G50/52
964 (965) Turbo 1991-94
Rod shift
Single-plate clutch
Gear ratios:
1st gear: 3.154
2nd gear: 1.789
3rd gear: 1.269
4th gear: 0.967
5th gear: 0.756
5th gear 0.767
If anyone can help or advise I would greatly appreciate it.
Thanks in advance
Chris Hawes
Milton Keynes, UK
or you can email me changing AT to @ ChrisATdelorean-hire.co.uk
Thanks Cable guy. I'm already searching eBay and other forums as these boxes aren't as easy to find as they once were. I was hoping someone on the forum might see this and remember that they have one in storage that they had meant to get around to selling. :D
if you are still looking for a G50/52 I got one for sale.
90000km
Price SEK 75000:-
Is avalible in Gothenburg, Sweden.
BR
Peter
Thanks for the offer. I'm glad you've posted this here as someone else will surely stumble on this thread and reach you.
I was very fortunate, I found a specialist here in the UK that had an zero mile G50\52 in its crate (and Porsche tags). He'd been saving it for a project, but each project ended up having the G96 or G97 turbo variants. Once he learnt of my tight space issues and that it was for a V8, then it made the perfect choice. It then had a G50\50 nose cone transplant and my conversion this weekend will have just ticked past the first 1000 miles on the gearbox. It will then have its oil drained and changed.
For a new/rebuilt G50\52:-
Oil Specification: Oil Capacity (approx.) 3.7L, API classification GL5 75/90 (this type if important due to the LSD)
Recommend an oil change at 1,000 miles initially then approximately every 10,000 miles thereafter but also dependent on usage. If heavy track usage or drag strip usage change oil every 5,000 miles.
124,555
1,441,471
48,968
biel
