997 : 2004- 71
996 : 1997-2005 34
Boxster : 1997- 25
The return of Marty Wild
PostPosted: Mon Jul 31, 2017 10:25 am    Post subject: Cayman S 987 Side sill trims and bonnet button trims Reply with quote
Hey Guys, does anyone k now the part numbers for the side sills and the trim beside the sills?
Would like to replace them in a perfect world, don't mind sticking to the standard plastic parts, are they crazy expensive?
Boxster S 986.1
Cayman S 987.1 (gone but not forgotten)
PostPosted: Mon Jul 31, 2017 6:46 pm    Post subject: Reply with quote
Your rear quarter panels or mudflap housing is no. 10 here ..
http://www.deroure.com/diagrams.asp?MAK=3&MDL=36&TBL=5268&SMA=&SMO=0&ST=&SC=0
Buggered if i can find the side seals though on that site ..
Theres a certain parts guy you could ask in a few weeks though if that helps Wink
PostPosted: Tue Aug 01, 2017 10:16 am    Post subject: Reply with quote
Cheers Demort, not sure about that first link, I am literally thinking the kick plate (sills) and the trim that houses the bonnet release buttons and its equivalent.
Boxster S 986.1
PostPosted: Tue Aug 01, 2017 10:19 am    Post subject: Reply with quote
Figured if I could source all the bits, might be nice to have an expert fit them should they find themselves working on my car! Laughing
Boxster S 986.1
PostPosted: Tue Aug 01, 2017 6:47 pm    Post subject: Reply with quote
Floor
My mistake .. the switch panel trim should be no 5 here , fixings wont be required as you reuse the old ones ..
http://www.deroure.com/diagrams.asp?MAK=3&MDL=36&TBL=5285&SMA=&SMO=0&ST=&SC=0
Is no. 12 the other part you need ?
PostPosted: Wed Aug 02, 2017 7:58 am    Post subject: Reply with quote
You Sir, are a legend!
This is exactly what I am on about! As you say, 12 is the other part, will really freshen her up =)
Boxster S 986.1
PostPosted: Thu Nov 22, 2018 10:21 am    Post subject: Reply with quote
Sorry Iain, the link died, could you refresh it when you have a moment please?
Boxster S 986.1
PostPosted: Thu Nov 22, 2018 8:32 pm    Post subject: Reply with quote
I think this is the bit you need ..
https://www.deroure.com/diagrams.asp?MAK=3&MDL=36&TBL=5285&SMA=&SMO=0&ST=&SC=0
Strange as it seems to be the same link Dont know
EDIT ..
Aghhh Https:// .. not http://
Get well soon young man Very Happy
PostPosted: Fri Nov 23, 2018 4:09 pm    Post subject: Reply with quote
Many thanks, Demort. Now her indoors isn’t getting in the car, I’m definitely going to replace the sill trims.
And thanks for the wishes, you’re eagle eyed.
Boxster S 986.1
