997 : 2004- 71
Boxster : 1997- 13
monster
PostPosted: Fri May 10, 2019 10:50 pm    Post subject: Reply with quote
Ive had my 997 getting for 10 years now and its been through two pumps in that time.
The first one corroded through the cover as per the more usual failure mode, but the second one corroded through the takeoff spigot for the brake servo assist vacuum. This manifested itself by a complete loss of servo assist for the brakes rendering the car with seriously impaired braking capability.
It took me a while to pinpoint the actual cause of the problem as it wasnt obvious were the actual leak was coming from.
sja360
2007 Porsche 997 Carrera 4S
PostPosted: Fri May 10, 2019 11:08 pm    Post subject: Reply with quote
Out of interest is your car garaged and used all year around?
-- 997 --
PostPosted: Fri May 10, 2019 11:33 pm    Post subject: Reply with quote
Ok, interesting posts, so heres another question, to change the tandem pump what are the procedures, i.e. how is it tackled to take off? What needs to be stripped before the access the pump?
Cheers..
J
monster
PostPosted: Sat May 11, 2019 12:51 am    Post subject: Reply with quote
Its garaged now but wasn't for the majority of those years and was used all year round.
monster
PostPosted: Sat May 11, 2019 12:56 am    Post subject: Reply with quote
Cheers..
J
Just raise the rear of the car and its located on the rear of the engine on the offside. I think it's 4 bolts that hold it in place. There is also a length of aluminium tube that it is advisable to replace at the same which needs to come out through the space vacated by the air filter housing. Easy diy, just a bit fiddly to wiggle the aluminium pipe in and out.
PostPosted: Sat May 11, 2019 2:30 pm    Post subject: Reply with quote
All brake servos have a one way valve and its usually on the end of the pipe you actually push into the servo ... no check valve and on over run you would have no vacuum in the servo Smile
The Tandem pump replacement itself is not hard .. but if the bolts have seized they will just round out ( Torx ) .
In this case you have to remove the bumper and possibly the exhaust that's in front of it then being a bit brave start attacking around the bolts with a hammer and chisel to snap away the casing or try and drill them out .
i've used the hammer method a few times and its quite effective shall we say .
darkhorse
PostPosted: Sat May 11, 2019 4:57 pm    Post subject: Reply with quote
I replaced the cover with the ACP item and it worked perfectly. My tandem pump wasn't actually leaking but the cover was quite corroded in places. Had I realised the Pierberg full pump was £250 from autodoc I would have replaced the whole item!
Anyone got a link for this because I cant see one on the autodoc site
PostPosted: Sat May 11, 2019 5:58 pm    Post subject: Reply with quote
Cheapest i found ..
https://www.frazerpart.com/acatalog/Porsche-987-997-tandem-vacuum-pump.html?gclid=EAIaIQobChMI9o-8w4WU4gIVArTtCh2UlwemEAQYASABEgKEMfD_BwE
You will need the pipe that goes onto it as well though as these tend to corrode in and don't come out in one piece .
Turbos are different pumps though .
timbo1811
PostPosted: Sat May 11, 2019 6:39 pm    Post subject: Reply with quote
deMort, I'll see your Frazer part, and raise you an Autodoc........vat inc, free delivery and its OEM
Lotus Elan, Lotus Elan +2, MGA Mk11, TR4, 230 Compressor, 320 coupe, 944, Boxster 2.7, 997.1(current), VFR 1200, CBR 1100 Blackbird
PostPosted: Sat May 11, 2019 7:13 pm    Post subject: Reply with quote
https://www.autodoc.co.uk/pierburg/7890260
i always get confused by this , INC vat means it will be added ?
if so its £305 from autodoc Dont know
This is why i just fix cars and not do parts .. sigh ..
jl-c
PostPosted: Sat May 11, 2019 7:20 pm    Post subject: Reply with quote
INC = including Smile
EX = excluding
PostPosted: Sat May 11, 2019 7:38 pm    Post subject: Reply with quote
aghh thank you ...
Inclusive ..
including ..
sigh . i didnt know which .
jl-c
PostPosted: Sat May 11, 2019 7:43 pm    Post subject: Reply with quote
no problem Smile I agree it can be confusing.
Scholester
PostPosted: Sat May 11, 2019 10:15 pm    Post subject: Reply with quote
Turbos are different pumps though .[/quote]
This is the main reason why preventative steps/cover replacement should be carried out on the Turbo as replaments pumps are circa £1000
RJKflyer
PostPosted: Sun May 12, 2019 12:08 pm    Post subject: Reply with quote
To support those comments regarding ACF50 - my 997.2 turbo is now 8 years old and there is no appreciable corrosion.
997.2 turbo PDK
Goto page Previous  1, 2, 3
Page 3 of 3
