997 : 2004- 79
996 : 1997-2005 46
964 : 1989-1993 6
Boxster : 1997- 13
Cayman : 2005- 18
Cayenne : 2003- 8
912-914-924-928-944-968 3
angry
PostPosted: Thu Jul 27, 2017 12:21 pm    Post subject: Airbag delete Reply with quote
Ive had a Momo wheel on for a while and when I first got it I tried the Resistors to delete the airbag light. Pretty sure I tried 2.7 & 2.9 ohm, but they didn't work.
The 993 has now failed the MOT on amongst other things the airbag light!
Ive just tried a 3.3ohm to no success.....Any ideas chaps frustrated
996 Turbo
993 C2.
Pretzel
PostPosted: Thu Jul 27, 2017 4:16 pm    Post subject: Reply with quote
Duplicate post
993 C2 Aventura
ColinC
PostPosted: Thu Jul 27, 2017 4:42 pm    Post subject: Reply with quote
Sounds like you may have another issue - I used a 2.8 ohm with no issues when swapped out to the Cup wheel. Came in a kit from Gert.......
NottsRS
PostPosted: Thu Jul 27, 2017 5:43 pm    Post subject: Reply with quote
Has the warning light been on ever since you tried installing it a while ago? Once the fault light has been triggered you'll need to get a code reader to delete/reset it (T-OBD is a good bit of kit or take to nearby indy). Apologies if stating the obvious and you've already done this. Would have been triggered and stored when the incorrect resistor circuit had been powered up. If when cleared it triggers again then agree with ColinC there's another issue, possibly the SRS control unit or with the remaining passenger bag? HTH
964 RS | GP White | Lightweight
993 RS | Riviera Blue | Lightweight
GT3 RS | Viper Green
993 4S | Viola Metallic | Factory Non Sunroof | [Jan'09-Mar'16]
angry
PostPosted: Thu Jul 27, 2017 8:37 pm    Post subject: Reply with quote
Cool thanks for the input...makes sense, if a reset doesn't work I will bin the whole system...passenger as well.
996 Turbo
993 C2.
stuttgartmetal
PostPosted: Thu Jul 27, 2017 9:06 pm    Post subject: Reply with quote
Take the bulb out.
angry
PostPosted: Sat Jul 29, 2017 4:46 pm    Post subject: Reply with quote
Had the whole system reset, fitted 3.3ohm airbag resistor light gone. 3 miles down the road to home, light back on again frustrated
996 Turbo
993 C2.
