997 : 2004- 76
996 : 1997-2005 48
964 : 1989-1993 5
Boxster : 1997- 18
Cayman : 2005- 15
Cayenne : 2003- 9
Macan : 2014- 1
912-914-924-928-944-968 3
trig_112
PostPosted: Thu Jul 27, 2017 10:38 am    Post subject: Another 'should I change my IMS bearing' thread Reply with quote
Yes, another 'should I change my IMS bearing' thread, but before you all wring your hands, shout at the screen and give the usual replies, hold on a second.
When I bought my car, it had an invoice to say an IMS single row bearing retrofit kit had been installed, along with a new RMS/clutch. All good I thought, the pin is back in the grenade.
But, after seeing a few comments about the LN engineering bearings, I'm not sure the pin is fully secure in the grenade, more like just about in, slowly falling out.
I'm a little worried, because the indy that fitted it thinks the part number on my invoice related to a LN kit, which seem to have a higher failure rate than the original Porsche one.
So, back to the title question. Its been about 10k miles since the LN went in. Should I be looking at getting it replaced?
I'm not expecting the answer to be 'GET IT OUT NOW!', should I be budgeting for it to be done at the next service?
Garage:
2004 996.2 C2
2008 Alfa Spider
2016 Evoque
1987 Escort RS Turbo
Countless spares and push bikes
Past Porsche: 1983 924
Martin996RSR
PostPosted: Thu Jul 27, 2017 12:42 pm    Post subject: Reply with quote
The problem is that you can't know whether it's on its way out unless you take it out and examine it. I would budget for replacement with a stock bearing, just with the dust cover removed, in 10-15,000 miles' time. Obviously you should carefully examine your oil filter at each service for signs of breakup, but really the best you'll be able to do with this is informed guesswork rather than 'it's definitely on its way out'..
955matt
PostPosted: Thu Jul 27, 2017 1:22 pm    Post subject: Reply with quote
Just drive the car and dont worry about what might happen.
Very Happy Very Happy
Dammit
PostPosted: Thu Jul 27, 2017 2:00 pm    Post subject: Reply with quote
Do you have other maintenance tasks that would make sense to be done at the same time? Clutch, AOS, that tensioner you can't get to with the engine in place etc? If so it would make sense to take care of everything at once- if of course the price is acceptable. Otherwise I'd leave it until you do have other tasks to help make sense of the cost.
What's the mileage of the car now?
arry
PostPosted: Thu Jul 27, 2017 5:20 pm    Post subject: Reply with quote
That. Just get on with it.
If it goes massive tits up then the monetary risk isn't massive.
2001 Lapis Blue 996 C2 Manual
2012 Orange KTM 990 SMT
2016 Marsh Grey Royal Enfield Bullet 500
alex yates
PostPosted: Wed Aug 02, 2017 6:34 pm    Post subject: Reply with quote
I'd wait until the opportunity arises (like a clutch change), then have a gander at what's there and take action from there.
Sun's out Gun's out.
skinny_monkey
PostPosted: Wed Aug 02, 2017 7:15 pm    Post subject: Reply with quote
from memory the Americans change their LN bearing every 40k miles
955matt
PostPosted: Thu Aug 03, 2017 6:58 am    Post subject: Reply with quote
They also voted in Donald 911uk Floor Floor Floor Floor Floor
trig_112
PostPosted: Fri Aug 04, 2017 10:32 am    Post subject: Reply with quote
Annoyingly the clutch and RMS were done at the same time so in theory it is the IMS bearing that needs replacing next.
I got confirmation from the indy that fitted it, it is a LN bearing, replacement schedule is 40k miles, to replace it will be £1800 +vat.
It was done 13k miles ago, so leaving it a few years shouldn't be a problem. As suggested, leave it until something else needs doing, like the dreaded brake pipe corrodes and deal with it when the engine and box is dropped.
Garage:
2004 996.2 C2
2008 Alfa Spider
2016 Evoque
alex yates
PostPosted: Fri Aug 04, 2017 10:36 am    Post subject: Reply with quote
1. They ripping you off quoting £1800 to change the bearing.
2. Engine doesn't need dropping to replace the brake pipes if cunifer pipe is used (more superior than the rubbish ones Porsche fit). My mechanic charged me £80 to replace my pipes.
