Hi all, long time lurker in need of some help please.
I have a Dension Gateway 500S which I've installed via the back of the PCM,
however I'm not having any luck getting it to work.
I've rechecked the usual suspects - dip switches, direction of fibre optics,
and have the unit running directly off a battery for test purposes.
My suspicion is that the unit is not powering up.
My question is should I see any LED indication on the connector port
as soon as the unit has power, regardless of the other connections?
So far, I have not been able to get the LED to do anything, either in
active or bypass setting.
Thanks in advance.
Thanks in advance.
