easttorks964cab
- Joined
- 2 Jun 2008
- Messages
- 163
Hi Guys,
my aircon hasn't worked for a while, so I decided to gas it up and see if she would fire up.
so its now gassed, when you switch aircon on, the compressor (I presume) kicks in, which you can hear and also the revs raise and the blowers go full tilt.
Unfortunately, no cold air! any advice at what I should be looking at next?
UPDATE::
It seems that the compressor clutch isn't engaging. you can spin it manually, so its not seized, but it doesn't spin when aircon is turned on.
ive checked the fuse, which is fine.
cheers
Chris
UPDATE::
cheers
Chris
