I'm going to getting the wheel alignment set on my car but I'm going to ensure everything moves first, the only problem I'm having is with both eccentric bolts on the lower arms.
I've gave everything a good spray with ac90, the nut comes off eccentric bolts easy on both but I was wanting to take both bolts out to clean up and lube etc, the eccentric bolt does turn but it looks to me as if it moving the bush with it, I dare say the alignment could still be set up but surely this can't be doing the bush any favours or does this not matter as long as the alignment is correct.
Any tips on removing the bolts
