996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
ajmclean
PostPosted: Thu Jul 13, 2017 11:36 am    Post subject: Oil Leaking Reply with quote
Hi guys,
I topped up oil this morning before a 45mins drive. Notice this after couple of hours after parking. Recently had AOS replaced and Clutch depress switch replaced.
Please see the photos below
https://ibb.co/c9mRaF
https://ibb.co/ixrg9a
https://ibb.co/k9nM9a
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Thu Jul 13, 2017 11:50 am    Post subject: Reply with quote
Hmmm.
That's quite a lot!
Any pics of the origin of the oil?
Did you top up as a regular check our did you get a warning?
How much did you add?
What does the electronic dip stick say now?
Any history of leaks or odd noises?
How old is it and does it still have the original tandem pump?
ETA: source looks to be close to the AOS I believe.
Possible source, esp. If no history of leaks previously.
jonno_
PostPosted: Thu Jul 13, 2017 2:00 pm    Post subject: Reply with quote
Looking on a bigger screen now... in that first pic, the drip forming looks pinkish to me.
Can you try tasting it or putting some on some white kitchen roll perhaps?
That'll narrow down the possibilities. I think it could be coolant. Check the cap on the expansion tank, and also the tank itself. Both possible weak spots.
Reims
PostPosted: Thu Jul 13, 2017 6:08 pm    Post subject: Reply with quote
Jonno is right .. its coolant and not oil .. the coolant header tank is above there .. i expect its split at the seams .
Just to point out as ive seen it mentioned a few times and to be honest its how i used to check it but ..
Antifreeze is toxic so a taiste test these days at least in my trade is kinda frowned upon .. in other words if I do it i get shouted at Very Happy
At an Indy these days !
seeforez
PostPosted: Fri Jul 14, 2017 11:21 pm    Post subject: Reply with quote
That cheap vodka i bought the other week from the guy outside the shop who said he had bought 2 bottles by mistake tasted just like antifreeze - so it must be ok to drink? Very Happy
