996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
k11pol
PostPosted: Wed Jul 12, 2017 9:17 pm    Post subject: Trying to find spec of car when new ! Reply with quote
Does anyone know how I can find the full spec of my car when it was new ? I obviously know most of it but might be missing a few things.
isysman
PostPosted: Wed Jul 12, 2017 9:19 pm    Post subject: Reply with quote
Any Porsche dealership should be able to give you this info. Also you can apply for a Certificate of Authenticity from Porsche which will have the info on also.
911 GT2RS Build
987 Boxster S 3.4
k11pol
PostPosted: Wed Jul 12, 2017 9:36 pm    Post subject: Reply with quote
That's good news, I'm booking it into Porsche next week for a service so will ask for the info at the same time, thanks
M9JOC
PostPosted: Thu Jul 13, 2017 12:25 pm    Post subject: Reply with quote
There should be a sticker on the service book with the spec details
2007 (57) Porsche 997 Turbo (Tip) in Slate Grey
20" HRE Alloys on Continental tyres, 9E Stage 2 inc IPD,TB & chrome Y-Pipe, Europipe+100CEL, -20mm H&R springs. Gen 2 front & Rear bumpers, Chrono, Adaptive Sports Seats, Full Porsche Aerokit
k11pol
PostPosted: Fri Jul 14, 2017 7:34 pm    Post subject: Reply with quote
I asked for the spec while car was being serviced today and they printed it off no problem.
Swampy
PostPosted: Sat Jul 15, 2017 1:00 pm    Post subject: Reply with quote
M9JOC wrote:
Have just found the sticker in my service book, had a Google and found this page for seeing what's what, Not all codes are listed, I cant find code 250, also the code starting with a letter.
Not wanting to hijack the thread but in the car handbook it mentions the mirror tilt when reversing (where the passengers mirror tilts down when reverse is selected). Does anyone know if this is a feature to all cars or can I assume mine is not working.
[/url]https://www.porscheclubgb.com/PCGB/media/R31%20assets/Docs/Porsche-Option-Codes.pdf?ext=.pdf
Swamps Smile
maph
PostPosted: Sat Jul 15, 2017 1:31 pm    Post subject: Reply with quote
To activate the dipping side mirror the mirror adjustment switch needs to be turned to the passenger side. If it is it should work.
2012 997.2 Turbo S
Swampy
PostPosted: Sat Jul 15, 2017 2:02 pm    Post subject: Reply with quote
Thanks Maph, I read that and tried it, and no it doesn't work Sad
The car is going back to Porsche at the end of the month to have the rear light cluster looked at as it has condensation (under warranty I hope), I was going to ask them to look at the mirror but I didn't want to look like a plonker if it wasn't fitted :-O
Swamps Smile
maph
PostPosted: Sun Jul 16, 2017 7:27 am    Post subject: Reply with quote
Hi Swampy,
Does yours have memory seats? If so you can set the dipped mirror position for each button/ key.
If you do have memory I would check that the dipped position has not been accidentally set to the same position as the non dipped if that makes sense.
Failing that it does indeed sounds like you need it checked out.
2012 997.2 Turbo S
TonyC911
PostPosted: Sun Jul 16, 2017 7:45 am    Post subject: Reply with quote
Dipping reversing mirror is part of the memory seat package only.
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
basildon993
PostPosted: Sun Jul 16, 2017 9:00 am    Post subject: Reply with quote
Option 250 is 7-speed PDK (dual clutch) transmission.
What other option codes can't you find?
997.1 Turbo Coupe Manual
ex 993 Carrera 2 Manual
ex 3.2 G50 Carrera Targa Manual
ex Chevrolet Camaro IROC Z Manual
Swampy
PostPosted: Sun Jul 16, 2017 12:30 pm    Post subject: Reply with quote
maph wrote:
Hi Swampy,
Thanks Maph for you input, I do have the memory seats and I know exactly where you are coming from with regards to the reverse setting being the same as the non dipped setting , last night I had a re-read of the owners manual and I have done the following,
Mirror control switch on passenger
1 ignition on
2 select reverse
3 adjust the mirror as preferred
4 press M and hold and then press 1 on the door panel (get a quick bleep).
Then if I drive off as mirror should return to normal non dipped position once car reaches 4mph I think it is but it doesn't, stays where it is.
If I then return it to a non dipped position manually, then select reverse mirror stays the same.
I think I'll let them sort it out as I really would like this feature as so not to kerb the wheels.
Swamps Smile
Swampy
PostPosted: Sun Jul 16, 2017 12:31 pm    Post subject: Reply with quote
Thanks TonyC911, i do have the memory seat package Smile
Swampy
PostPosted: Sun Jul 16, 2017 12:49 pm    Post subject: Reply with quote
Thanks Basildon, I initially only wanted to find out if I had a dipped mirror when I started to read this thread (Thanks k11pol) but then curiosity went on from their.
I have attached a picture of my spec so now its just the ones that start with a letter that I couldn't find eg the first three rows.
Swamps Smile
 Filesize:  15.81 KB
 Viewed:  1469 Time(s)
basildon993
PostPosted: Sun Jul 16, 2017 7:34 pm    Post subject: Reply with quote
MA1.01 Engine Type
CG130 Transmission code for a 7 speed PDK transmission manufactured by ZF Friedrichshafen, Germany
Not sure of the 'L' but C9Z is the Paint code for Basalt Black (Z4)
AT - Black Full leather interior
C16 is the Country Code - United Kingdom
XES - Not on my list! Porsche Exclusive Option maybe?
XXB is a Porsche Exclusive Option - Door entry guards stainless steel and illuminated
Hope that helps a little. Smile
Swampy
PostPosted: Sun Jul 16, 2017 8:30 pm    Post subject: Reply with quote
basildon993 wrote:
MA1.01 Engine Type
That all sounds about right to me basildon993 and thanks very much Smile
I have just had a little Google and XES = Preparation for illuminated door entry guards ....and how nice they are I must say Smile
Swamps Smile
