997 : 2004- 66
996 : 1997-2005 43
993 : 1993-1998 9
964 : 1989-1993 7
Carrera SC : 1977-1983 0
Classic : 1950-1965 1
Boxster : 1997- 15
Cayenne : 2003- 9
912-914-924-928-944-968 4
3point6
PostPosted: Wed Jul 12, 2017 9:14 pm    Post subject: Spaced out! 15mm all round.. Reply with quote
Fitted spacers today. 15mm all round. Arches are filled out just lovely...
 Filesize:  113.67 KB
 Viewed:  1450 Time(s)
 Filesize:  121.6 KB
 Filesize:  117.89 KB
 Filesize:  140.66 KB
adamw
Estoril
2002 Porsche 996 Turbo
PostPosted: Thu Jul 13, 2017 6:26 am    Post subject: Reply with quote
Looks great !!
May consider doing this on mine at some stage ! Do you mind me asking what they set you back and where you purchased?
Also does anything need to be done in terms of geo setup after fitting ?
02' 996 Turbo Manual Coupe, Seal Grey
Harv
PostPosted: Thu Jul 13, 2017 7:55 am    Post subject: Reply with quote
Looks great! Are you on standard springs?
I have a set of 15mm spacers to fit which were a bargain from Amazon
https://www.amazon.com/gp/aw/s/ref=is_s?k=5+x+130+15mm+spacers
I may lower the car to complete the look but not sure how much to drop it by and think it's probably best to go with a coil over adj kit at the same time to refresh springs and dampers
3point6
PostPosted: Thu Jul 13, 2017 9:19 am    Post subject: Reply with quote
I got these from an auction site..
http://www.ebay.co.uk/itm/Porsche-Boxster-Cayenne-15mm-Hubcentric-Wheel-spacers-and-Radius-Bolts-5x130/302005355729
..but if you buy that, you'll need to ask for the correct bolts (the ones above are wrong). Cost £150 for the 4 spacers and 20 bolts.
Yes, i'll probably need to get the geo checked, I dont think it'll be out but may need tweaking.
adamw
Estoril
PostPosted: Thu Jul 13, 2017 9:36 am    Post subject: Reply with quote
Cheers both
Refresh springs and dampers also on list at some stage too so maybe I'll fit these at some time then get fill geo.
Growing list Grin
Bund
PostPosted: Thu Jul 13, 2017 10:39 am    Post subject: Reply with quote
Looks good.
Did you look into Mtec? HC are they way to go of course, I've just put spacers on an old Toyota LC which is unlikely to go over 70mph and they cost £120 with bolts and not HC, the HC type for my car were closer to £300. A car that's capable of 200 i'd want to know those spacers are top notch.
996 Turbo X50, Caterham R300S race car, RR Sport, Toyota LJ70, JCB telehandler
3point6
PostPosted: Thu Jul 13, 2017 11:41 am    Post subject: Reply with quote
It won't be doing anything even near 200mph with me inside it, that's for sure. Thumb Cop I used mtec's on my last two 6t's, but this is the first time I put them on the front as well.
Yes, that is standard springs, it was sitting a little high when the pics were taken, I expect it has settled down overnight after being jacked up to remove the wheels.
Yas.SYC4S
PostPosted: Thu Jul 13, 2017 1:52 pm    Post subject: Reply with quote
Looks great thumbsup
I ordered 15mm & 18mm black RSS spacers set from JZM. Cant wait to fit them! Going by your pics the stance is awesome with 15mm and stock ride height.
Speed Yellow - 996 C4S (EVO Magazine)
Guards Red - Porsche 924 (1982)
Alfa Red - Alfa Romeo 1750 GTV Mk1 (1968)
Laguna Seca Blue - BMW M3 E46 (2003)
Mac996t
2004 Porsche 996 Turbo
PostPosted: Fri Jul 14, 2017 12:09 am    Post subject: Reply with quote
Looks good, have you noticed any difference in steering weight or feel e.g. More/less tram lining etc?
Also do you think there's any chance of the tyres touching the arch lips?
Cheers Mac
3point6
PostPosted: Fri Jul 14, 2017 10:33 am    Post subject: Reply with quote
Not much difference if anything at all.
Last time, i installed only rear spacers and that made the car feel a little heavier and planted at the rear.
This time i did all four, cant feel much difference. Maybe a little less overall feeling through the wheel if anything.
I dont think they will rub, not with stock ride height anyway.
paul987
PostPosted: Fri Jul 14, 2017 11:45 am    Post subject: Reply with quote
They look very very good Thumb
In fact so good I really need to buy some Grin
2001 996 C4S - Silver
2006 987 Boxster S 3.2 - Guards red
3point6
PostPosted: Fri Jul 14, 2017 11:51 am    Post subject: Reply with quote
Thumb Do the right thing!
911munKy
PostPosted: Fri Jul 14, 2017 1:08 pm    Post subject: Reply with quote
Mine did on the rear with 295 Conti's on stock suspension over speed bumps etc, it may have been a combination of the wider tyres and camber settings. I rolled the arches and it's been fine since and also on my last geo I added more negative camber.
No one else seems to have a problem though.
2000 C2 996
