996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayman : 2005- 17
Cayenne : 2003- 7
edh
PostPosted: Wed Jul 12, 2017 3:36 pm    Post subject: Headlight removal problems Reply with quote
Looking for clues here....
I managed to change one headlamp easily enough, a bit of silicon spray on the runners helped the replacement slide in smoothly
The second won't budge - using the removal tool to turn the lever just results in a loud click but no movement of the headlamp
Obviously this is also a problem if I want to change bulbs..
Can I get at it from the wheel arch if I remove the liner?
Any other tips?
Ed
Halcyon
PostPosted: Wed Jul 12, 2017 3:42 pm    Post subject: Re: Headlight removal problems Reply with quote
Yes, you can Thumb May be the only option if it's stuck there.. Remove the liner and you'll be able to push it from the back of the unit
996.2 Carrera 4 Convertible Tip
edh
PostPosted: Wed Jul 12, 2017 5:53 pm    Post subject: Reply with quote
Sorted - thanks Smile
How many different types of fastener do they use on those arch liners! - I hate those trim clips...
