996 : 1997-2005 42
993 : 1993-1998 9
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayman : 2005- 17
Cayenne : 2003- 7
Jabbah
PostPosted: Mon Jul 10, 2017 11:32 am    Post subject: Low washer pressure Reply with quote
The front windscreen washer pressure has dropped significantly and more on the N/S that the other. I tried topping up the washer fluid (not much needed) and tried the jets again and lots of washer fluid from under the car on the N/S. Guessing a split pipe somewhere? Is there an easy way to take off the plastic cover around the washer jets to check?
Martian
2007 Porsche 997 Turbo
PostPosted: Mon Jul 10, 2017 11:52 am    Post subject: Reply with quote
A common problem is the pipe coming away from the headlight washers. Think you can get to them underneath the car in that area without removing the liner or bumper.
Jabbah
PostPosted: Mon Jul 10, 2017 2:48 pm    Post subject: Reply with quote
Is the same pump used for the windscreen washers as the headlights? Do they only wash if you have the headlights on at the same time?
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Mon Jul 10, 2017 4:14 pm    Post subject: Reply with quote
Different pump to windscreen washers.
Bi-xenon wash only when headlights are on when you press the tiny stalk button, or every 3(or is it 5?) washes of windscreen when lights are on and front control unit doesn't need a handover reset.
I prefer operation on the button, as it goes all over the front of the car just when you don't want it to
