997 : 2004- 79
996 : 1997-2005 46
964 : 1989-1993 6
Boxster : 1997- 13
Cayenne : 2003- 8
912-914-924-928-944-968 3
ch3tman
1995 Porsche 993 Carrera 4
PostPosted: Thu Jul 06, 2017 7:47 pm    Post subject: 993 rear lower wishbone - options Reply with quote
Hi all,
An annoying squeaky noise developed on my 993... It wasn't the easy to address culprit (ARB bush) and appears to be the rear lower wishbone bush - to be investigated/confirmed in the coming days.
Thinking about replacements, I'm led to believe the whole lower wishbone needs to be replaced, rather than the bush only...Confused So, options:
1] Retro Line : £125+VAT
2] Dansk : £150+VAT
3] OE Porsche : £440+VAT
Should any other options be considered? Can't seem to locate TRW parts - any pointers?
Also, can anyone vouch for the Dansk item, or should this be an OE part only job?
Many thanks!
(edited to reflect recent increase in price increase of OE item, since posting!)
cableguy
PostPosted: Thu Jul 06, 2017 9:18 pm    Post subject: Reply with quote
I'm sure Hartech offer these also, basically a fully refurbished unit with new bushes pressed in. Wink
C.
Pork!
Sutton
PostPosted: Thu Jul 06, 2017 9:19 pm    Post subject: Reply with quote
ZF bought TRW a couple of years ago so maybe the parts are available via ZF?
1994 993 C4
ch3tman
PostPosted: Thu Jul 06, 2017 9:37 pm    Post subject: Reply with quote
Thanks cableguy & Sutton - very helpful thumbsup. Will speak to Hartech tomorrow! Couldn't find much on the ZF parts catalogue (https://webcat.zf.com/index.asp?SPR=4) on first glance but will continue searching. No luck on RosePassion whilst the TRW items on mister-auto are 'out of stock'.
ColinC
PostPosted: Thu Jul 06, 2017 10:00 pm    Post subject: Reply with quote
Check out Jackals DIY, easier with poly bushes - it's a day combined with some beers and the usual OCD cleaning along the way......
http://www.jackals-forge.com/lotus/993/993_diary.html#BUSHES
ch3tman
PostPosted: Thu Jul 06, 2017 10:28 pm    Post subject: Reply with quote
Thanks - though that's regarding the front wishbones...
Is the same story with the rear lower ones? My indy advised its a replacement job...
jcbaldock
PostPosted: Fri Jul 07, 2017 5:35 am    Post subject: Reply with quote
I went around the houses with this last year and ended up with Dansk arms. Hartech had no stock (and no ETA) for refurbed ones, but that's the route I'd have gone given the choice.
wozy
PostPosted: Fri Jul 07, 2017 6:11 am    Post subject: Reply with quote
I replaced every component of my 993 suspension last year. Have you a squeak or a knocking, if it's the former then I never had a squeak until I fitted new lol. So becareful, as if it's a squeak it may just be a rubber bush making itself heard and nothing else.
TRW parts non OPC supplied are as rare as hens teeth now, as Porsche forced the factory to stop supplying directly to third parties around 18 months ago. I was lucky, I managed to source an A frame for only £200, not a chance now. eBay is your friend, especially the European sites, Germany Poland etc
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
Cameltoe & Heel
PostPosted: Fri Jul 07, 2017 7:07 am    Post subject: Reply with quote
I went for Hartech refurb replacements, sat in my parts pile at the moment.
Basically the bushes need doing and the balljoint, you want all three mount points solid.
A chap on here Rob_watti has installed the Dansk units on the rear of his 993 so maybe worth a pm to him, when I spoke to him he seemed impressed.
I know fvd.de have them but I think pricey due to current exchange rate.
Trev
ColinC
PostPosted: Fri Jul 07, 2017 8:48 am    Post subject: Reply with quote
Ah....the rear eh, that's the bit at the back.......haven't reached there - started at the front, imagine my surprise when no engine was found Dont know
ch3tman
PostPosted: Fri Jul 07, 2017 9:55 am    Post subject: Reply with quote
Definitely the former, my indy advised there's nothing wrong otherwise, it's not dangerous, etc. and that any fix would be solely be addressing the annoying noise... and it is very annoying!
rob_watti
PostPosted: Fri Jul 07, 2017 4:57 pm    Post subject: Reply with quote
Trev
Yeah i did the Dansk ones and the quality seemed good to me but i guess only time will tell. I had a ball joint gone on my offside one but replaced both so everything matched side to side. I still have my old arms as i was hoping to find somewhere to refurb them.
ch3tman
PostPosted: Fri Jul 07, 2017 7:46 pm    Post subject: Reply with quote
Thanks all, for the input.
Given the choice, Dansk new or Hartech refurbed? Question The latter carry a 24 month warranty.
Dream911
PostPosted: Fri Jul 07, 2017 8:29 pm    Post subject: Reply with quote
Go Dansk, I've recently had mine replaced and the Hartech one I received had a stiffer bush so sent it back and went with the Dansk. Might be ok if you are replacing both sides but I was only doing one and was happier with the Dansk item.
I have nothing against Hartec and used them for my front wishbones on my 964 hence why I went to them first.
antong
PostPosted: Mon Jul 10, 2017 12:24 pm    Post subject: Reply with quote
For my two pennies, if the balljoints are ok then rebushing isn't a terrible job. I did the whole back end on mine with elephant racing bushes and have been really please with them. I think all the bushes including import duty cost me about £350...
