997 : 2004- 64
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 10
Cayenne : 2003- 4
Macan : 2014- 1
Endoman
PostPosted: Sat Jun 09, 2018 9:45 am    Post subject: Reply with quote
Not mine but another broken belt from a 964 sent to Didi for rebuild. My mechanic asks me to send them as he's not really into IT. Incredible service last one was back in 3 days. Seems to be more common with 964s than 993s as some do not have the breather pipe. There may already be a problem as no 5 cylinder is not firing on the single dizzy. When I did the dizzy caps the belt looked fine but I will get it done this winter. If you have a 100k + motor it's something to consider doing.
Diddi
PostPosted: Sun Jun 24, 2018 6:54 pm    Post subject: Reply with quote
@ Endoman,....... everything ok, I can sign blind! But the breather pipe alone does not save the Dizzy, often the Bearings are rusted and without fat (~ 20 years old !!) An old, cracked Belt is tired and tears off or freak out !! - CONTI specifies 7-8 years exactly as in the field of camshaft drive for other engines.
Service or parts for your dizzy - Infos D964@gmx.de
.... the belt looked like this - the Bearings were also at the end ........
 Filesize:  759.95 KB
 Viewed:  2701 Time(s)
Diddi
PostPosted: Sat Aug 04, 2018 11:18 am    Post subject: Reply with quote
........new belts CONTI CT-1032 production date 2018 arrived !!
&........ Bearings !
Grüsse, Diddi
 Filesize:  1.51 MB
 Viewed:  2348 Time(s)
Diddi
PostPosted: Sun Oct 28, 2018 6:53 pm    Post subject: Reply with quote
…….Special Offer:
….. here for : 180,00€
Grüsse, Diddi
 Filesize:  1.31 MB
 Viewed:  1814 Time(s)
Jack D
PostPosted: Sun Oct 28, 2018 11:11 pm    Post subject: Reply with quote
Hi Diddi, what do you charge for supplying the belt and doing the work ?
Regards
Jack D
Diddi
PostPosted: Sun Oct 28, 2018 11:45 pm    Post subject: Reply with quote
Hi Jack, I sent you an info for your question
Grüsse, Diddi
Diddi
PostPosted: Fri Jan 11, 2019 6:33 pm    Post subject: Reply with quote
Hi all,
Special offer until 31.01.2019 I can order for interested People:
https://www.mittelmotor.de/cms/de/component/acymailing/mailid-113?key=Ahym7AtI&subid=19948-SvGxdWmGHgZSFo&tmpl=component
Grüsse, Diddi
Endoman
PostPosted: Sat Jan 12, 2019 12:45 pm    Post subject: Reply with quote
A tip when reinserting the distributor.
I used a paint pen to mark the rotor arm positions when I pulled the distributor. If you loose these as I did, presuming you set the engine at TDC with the rotors aligned with the pip on the housing.
Remove the o-ring on the shaft (carefully) it will be tight to get it out otherwise. Trial fit and watch how the rotors move. Set the rotor center line 10.5 mm anti clockwise from the pip measured at the rim and you should be bob on. Refit the o-ring and ease the dizzy back in with a coating of oil on the o-ring and shaft.
 Filesize:  116.93 KB
 Viewed:  980 Time(s)
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Sat Jan 12, 2019 6:40 pm    Post subject: Reply with quote
My previous post mentioned an outfit in Germany who sell everything including the one off size bearings.....FVD.
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
Endoman
PostPosted: Sat Jan 12, 2019 11:47 pm    Post subject: Reply with quote
Fvd are very good aber das kostet mehr als Diddi.
Not sure that tranlates as I intended, Didddi is cheaper.
Sutton
PostPosted: Wed Feb 20, 2019 11:09 am    Post subject: Reply with quote
Diddi also did a good job on my distributor rebuild. Whilst the belt wasn't broken, it was looking tired and the bearings were rusty and had very little grease left.
1994 993 C4
Diddi
PostPosted: Fri Mar 08, 2019 11:29 pm    Post subject: Reply with quote
Thanks Sutton, and you can drive more relaxed with revised Dizzy!
Information, spare parts, offers for revision, special instructions can be found under PN or D964@gmx.de
Grüsse, Diddi
Goto page Previous  1, 2, 3
Page 3 of 3
