997 : 2004- 71
964 : 1989-1993 5
Boxster : 1997- 20
Cayenne : 2003- 4
decgraham
PostPosted: Fri Dec 08, 2017 4:37 pm    Post subject: Reply with quote
Diddi wrote:
All,
decgraham ask:.........But isn't Diddi (d964@gmx.de ) offering a rebuild service too?
Yes, what do you need parts (kit) or complete revision - just email D964@gmx.de
original parts from CONTI, INA, FAG...........
Thanks Diddi,
I'm Ok at the moment but will be in touch if I need a rebuild.
ATB Smile
Endoman
PostPosted: Fri Dec 08, 2017 5:08 pm    Post subject: Reply with quote
There was a tale of a 964 owner whose belt broke at considerable knots and he ended up with a bent crank, holed pistons are more common but not as common as nothing, they usually break at start up so don't run with a broken belt. Recommended change is 100k Didi supplies full kit and repair as stated, Type 911 supplies belt, pin and rubber seal kit. Yet another winter project as mine has clocked 170k. Did I once say I was getting bored?
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Fri Dec 08, 2017 8:20 pm    Post subject: Reply with quote
Recently gave a mate who has a 964 Anniversary a hand with this job, he bought the bearings from somewhere in Germany, probably the place quoted as they are one off sizes either internal or external bore I can't quite remember.
We replaced all bearings and seals, a bit of a faff but doable if you are okay on the tools, freezing the bearings and heating the housing helped to assemble.
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
Cameltoe & Heel
PostPosted: Mon Dec 11, 2017 8:56 am    Post subject: Reply with quote
Great thread and makes a change to usual valuations....
Ok so I got mine done and re-installed on Friday PM, upshot is that it's a fairly doable job. I managed to remove just the primary shaft and install a new belt over the secondary shaft. Removal of the secondary shaft requires you remove the cap at the bottom which without destroying it seemed difficult and I had no replacement.
My bearings seemed in good order so I simply greased them up which has made my life a little easier.
Unit during install, your can see the two halves separated
After install and cleanup
The pin is actually tougher than you would imagine and took some serious persuasion to knurl over on both ends to prevent it coming back out, in fact I set-up my 10T bench press to help me out.
The real key to all of this process is to ensure you align crank pulley and disis to the markings when you remove and when you put back, be extra careful during returning your disis back into the block, they engage with the driven shaft and move, this throws the set-up out of timing, you want the marking to line up exactly and you removed when the dissis are in situ, and not on the way out or in as they move due to the toothed gears.
You can see the rotor arms here aligned with markings on dissi case
My belt was in ok order but I did spot a slight fray, I'm glad I've done this job now.
Trev
Diddi
PostPosted: Mon Dec 11, 2017 11:15 am    Post subject: Reply with quote
.....ok, good Job !
The second runner should always be removed - that's what often looks like. The cap on the bottom can be removed with a small screwdriver and then brought back to shape. These two bearings often look chaotic !
I have all parts for your dizzy - Infos D964@gmx.de
 Filesize:  246.63 KB
 Viewed:  6548 Time(s)
Endoman
PostPosted: Mon Dec 11, 2017 12:45 pm    Post subject: Reply with quote
If you mangle the cap covering the lower bearing in the secondary housing they can be found on ebay, stainless even. Search under core/frost plugs/caps. Not started this yet but got one just in case. 1 1/4" from coreplugsintl.
 Filesize:  12.64 KB
 Viewed:  6522 Time(s)
AP90
PostPosted: Mon Dec 11, 2017 1:42 pm    Post subject: Reply with quote
Thank you for posting guys very informative...............one of the jobs on my overdue "to do" list on the 993
Cameltoe & Heel
PostPosted: Mon Dec 11, 2017 3:08 pm    Post subject: Reply with quote
I'm going to do a full engine rebuild in a few years so I'll swap the bearings then.
Trev
RXBoxster
PostPosted: Wed Dec 13, 2017 3:24 pm    Post subject: Reply with quote
Ive seen the belts on ebay here:
https://www.ebay.co.uk/itm/182659906248
johne
PostPosted: Mon Dec 25, 2017 5:59 am    Post subject: Reply with quote
wow more things to worry about
AVI_8
PostPosted: Fri Dec 29, 2017 1:17 pm    Post subject: Reply with quote
I replaced the belt on my 964 a few years back, it's not a difficult diy job and as others have posted there a a few links which give step by step instructions, the hardest bit was compressing the spring to get the circlip back on.
Just make sure the engines at TDC when removing the dizzy and that the rotors are correctly timed on refitting, they turn through around 30 degrees when pushing the dizzy back into the block due to the helical gear so it can take a couple of attempts to get the primary rotor to be positioned to cylinder 1 on refitting, it'll be obvious though if you're one tooth out on refitting.
Diddi
PostPosted: Mon Jan 01, 2018 5:43 pm    Post subject: Reply with quote
@all, Happy New Year !
.....in the new season only with revised ignition distributor - all parts in stock, 7201 bearings, Conti CT-1032 belt and more........ Infos D964@gmx.de
 Filesize:  58.37 KB
 Viewed:  5911 Time(s)
manners
PostPosted: Wed Feb 07, 2018 2:06 pm    Post subject: Reply with quote
Guys late to this but had this problem with my dizzy belt.
After i stripped the dizzy down it was apparent that I had a seized bearing which caused the belt to snap.
I ended up shipping my dizzy to Dennis at Elferwelt in Germany to be refurbished.
https://www.elferwelt.de/
A993LAD
PostPosted: Wed Feb 07, 2018 2:48 pm    Post subject: Reply with quote
Interesting . Their site looks good but all in German
How much did your rebuild cost?
How long did it take?
manners
PostPosted: Wed Feb 07, 2018 2:58 pm    Post subject: Reply with quote
Probably best to get a quote from Dennis but mine cost 318 euros. Which included replacement of the 4 bearings, belt and pin.
Found him via German ebay and I think he does work for Porsche museum although I could be talking crap...
Total turnaround time was 2 weeks.
A993LAD
PostPosted: Wed Feb 07, 2018 3:17 pm    Post subject: Reply with quote
Thanks manners
I might get a quote and then send it off. My car is running really well and my normal rule is to wait until something goes wrong before I try fixing it. But I'm thinking of driving it down to Italy in May for the Mille Miglia so it would be a shame if I've crossed the channel and then the belt breaks on the distributor.
Diddi
PostPosted: Thu Feb 08, 2018 3:48 pm    Post subject: Reply with quote
[quote="A993LAD"]
manners wrote:
Thanks manners
......is not good, engine damage by dizzy-belt is very expensive-come to me if you drive to the Mille Miglia and I overhaul your Distributor !!! Infos by D964@gmx.de
Diddi
PostPosted: Fri Mar 09, 2018 12:03 pm    Post subject: Reply with quote
yesterday disassembled oh my god .....
I have all parts in stock ask d964@gmx.de
 Filesize:  1.32 MB
 Viewed:  4741 Time(s)
PostPosted: Fri Mar 09, 2018 12:07 pm    Post subject: Reply with quote
All this looked far too technical for me so my Indy has swapped out the belt as a preventative measure Thumb
Some suggestion the belts are no longer available from Porsche Dont know
Diddi
PostPosted: Thu Mar 15, 2018 11:33 pm    Post subject: Reply with quote
no Problem, I have Bearings and CONTI-Belt ask d964@gmx.de
Page 2 of 3
