991 : 2011-2019 0
997 : 2004-2012 0
Boxster : 1997- 22
ColinC
PostPosted: Mon Jul 03, 2017 1:22 pm    Post subject: Broken Dizzy Belt..... Reply with quote
With only one rotor arm spinning I have deduced my belt has broken - anyone had there dizzy rebuilt in Scotland?
ColinC
PostPosted: Mon Jul 03, 2017 1:44 pm    Post subject: Reply with quote
Work commitments mean I'm not tackling this job myself so booked into Indy on Friday - bit disappointed really......
PostPosted: Mon Jul 03, 2017 1:51 pm    Post subject: Reply with quote
It can be DIY, but to be honest lining stuff up and remembering where all the leads go I'd leave it to someone who knows what they're doing.
http://p-car.com/diy/dualbelt/
My Indy will be changing mine as a maintenance item later this year Get Me Coat
The game's afoot. It's time to put a bit of (Colini) stick about......
Fourtuitous
PostPosted: Mon Jul 03, 2017 2:54 pm    Post subject: Reply with quote
I was planning to change the belt on mine as preventative maintenance because I had heard it can cause damage if the second distributor stops in the wrong place when the belt breaks. But after reading a "how to do it" article in one of the Porsche magazines I bottled out and asked my indie to fit exchange reconditioned dizzys with new Beru ignition lead set at the same time. I decided it was worth it for peace of mind and knowing that the complete distributors were as good as new rather than just the belt. Just checked my invoice. £964 including complete pair of Dizzy's, leads and labour. That was in 2013.
Cars, cars, fast, fast! One is seized, filled with enthusiasm, with joy... the joy of power.
The simple and naive pleasure of being in the midst of power, of strength.
Le Corbusier, The City of Tomorrow, 1929.
decgraham
PostPosted: Mon Jul 03, 2017 3:30 pm    Post subject: Reply with quote
As well as the link Zingari put up, here is another link to a guy who has a C4 and lives in Holland. I used his DIY to remove my steering rack and found his write up with pictures really helpful.
http://www.hd-electronics.nl/Hobby/repairs/rep_verdeler/20121209_rep_verdeler_993.pdf
ATB Smile
For a Yorkshireman that was a lot of dough Surprised
wozy
PostPosted: Mon Jul 03, 2017 4:17 pm    Post subject: Reply with quote
Blimey I hope you caught that quick. I was in Northway years ago and a bloke was paying for a rebuild on his 993 caused by the belt in the dizzys breaking.
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
ColinC
PostPosted: Mon Jul 03, 2017 5:16 pm    Post subject: Reply with quote
I too have heard horror stories however mine must have broken on a 200 mile trip from Aberdeen to home and the only issue I noticed was a slight but noticeable power loss........had a look over the car last night and when I removed the caps and cranked the engine by hand noticed the secondary rotor wasn't turning - everything else looks good,only changed them a couple of years ago, so I suppose it depends where the rotor arm stops. It starts on the button and I will remove the coil lead from the secondary dizzy before driving it the 10 miles to the Indy.....
Thanks for all the info - that Dutch fella explains things well - bookmarked👍
ColinC
PostPosted: Fri Jul 07, 2017 6:04 pm    Post subject: Reply with quote
Hey Wozy Indy agrees with you, reckons I was lucky - dizzy cap and rotor arm badly burned. 112,000 miles and 23 years on original belt - should be changed as preventative maintenance.
Diddi
PostPosted: Thu Dec 07, 2017 10:51 pm    Post subject: Reply with quote
............preventative maintenance for your Distributor = very important !
8)....all parts & Infos : mail to d964@gmx.de
All the Best,
Diddi
Cameltoe & Heel
PostPosted: Fri Dec 08, 2017 10:47 am    Post subject: Reply with quote
Chaps I have my distributer out at the moment and following the instructions on Dec's link above, seems fairly straightforward if handy with the tools otherwise I would leave it. You have to drill the old pin out and there's many parts that you need to understand how they go back together. Mine actually took some fairly gentle persuasion to come out of the block, which I can imagine if done with engine in situ would be a real pain.
Gives a good chance to clean up the block and dissis is places you can't easily reach.
Yes I can see why the labour cost would be high on this work.
Trev
A993LAD
PostPosted: Fri Dec 08, 2017 12:09 pm    Post subject: Reply with quote
Trev
This is a very interesting thread.
My car has done 126k miles and I can't find any record of the distributor belt ever being changed.
Having looked at the DIY links it looks relatively simple to remove the distributor unit. But then pretty complicated to get it apart and change the belt.
Is there a recommended supplier for a reconditioned exchange unit in the UK?
Also, if this is a waer and tear part that could have major implications when it fails, why on earth did Porsche position the belt inside the unit in a way where it needs to be entirely stripped down to install a replacement? That's just crazy.
Reminds me of replacing my alternator last year. I couldn't believe how much work and dismantling had to be undertaken to swap out the alternator for a reconditioned exchange unit compared to simply undoing two bolts on a normal car and completing the job in 10 minutes.
A993LAD
PostPosted: Fri Dec 08, 2017 12:20 pm    Post subject: Reply with quote
Good grief I just went on to the design 911 site to check if they sell, exchange unit distributors and they do.
Only £890 including VAT (plus £125 surcharge until the exchange unit is received) Surprised Surprised
That seems an awful lot of money to take somebody's old unit, open it up, change the belt, grease the bearings and put it back together again. Are there cheaper suppliers?
I see the list price for the belt and the pin is only £13, so maybe I will have a go at doing this myself afterall.
So do I spend my winter nights working on the 993 distributor, or do I fit the refurbished supercharger back on the Lagonda which is what I was planning to do?
Kat1
PostPosted: Fri Dec 08, 2017 1:07 pm    Post subject: Reply with quote
I seem to recall a guy who wrote in one of the specialist Porsche mags had a crank failure on his 964.
This was the infamous Peppermint Pig.
I believe the crank snapped and this was attributed to broken distributor drive belt.
A993LAD
PostPosted: Fri Dec 08, 2017 1:39 pm    Post subject: Reply with quote
Interesting
My next question was going to be how can a belt that does nothing apart from drive a little spinney thing outside of the engine cause catastrophic engine damage If it snaps?
I can understand it with a timing belt leaving valves in the down position when a piston comes up.
But if all spinney thing does is send Sparks to the spark plugs. Why does it damage main engine components when it stops spinning?
Marc
Kat1
PostPosted: Fri Dec 08, 2017 2:01 pm    Post subject: Reply with quote
As I understand it the spark reacts with the atmosphere to produce ozone which has the chemical formula O3 compared with oxygen O2
Ozone is so corrosive that when used commercially (water purification, washing contaminated laundry etc) it has to be produced at site and cannot be transported as there is no vessel material that is suitable.
I know that in laundry applications standard rubber components had to be changed for a different material due to premature failure.
It is the ozone that"corrodes" the belt so when Porsche became aware of this they put a clear plastic breather on the distributor to remove this gas as part of ongoing technical updates.
Now the speculation -
a) Maybe the modification was designed and tested over a relatively short period so with cars over 20 years old the rubber has deteriorated sufficiently to break.
b) Maybe deterioration of other components manifests itself as a larger spark and more ozone.
c) Maybe 20 year rubber is not that great generally.
I bi annually check that both rotor arms are turning and if I was to notice a slight drop in power I would even check these items at the side of the road.
Just disconnect the lead from each coil to distributor in turn and see if the car starts.
A993LAD
PostPosted: Fri Dec 08, 2017 2:17 pm    Post subject: Reply with quote
I think you've explained how the rubber belt would snap.
But the bit I don't understand is once the rubber belt has snapped and the second distributor stops spinning. Why would that cause significant damage to the engine at all?
Surely you just end up with one spark instead of two and life goes on?
Chris993C2
PostPosted: Fri Dec 08, 2017 2:49 pm    Post subject: Reply with quote
Depends where the rotor arm comes to rest - if it's on a contact, then that plug is going to be doing a lot of sparking...
decgraham
PostPosted: Fri Dec 08, 2017 3:59 pm    Post subject: Reply with quote
Hi All,
If you download the link I attached above you will see that Hans explains how to replace the belt only, which looks a lot easier than a full strip down like Trev is doing.
However, I have found the following outfit in Germany that offer different types of rebuilds, below is the cheapest.
https://www.fvd.net/de-en/930602015AX2ATK/distributor-964-993-dual-ignition-remanufactured-2-part-repair.html
But isn't Diddi (d964@gmx.de ) offering a rebuild service too?
I also contacted Peter Crago at Ignition car parts ltd (sales@ignitioncarparts.co.uk) but he came back to me and said that he had trouble getting the belt. As I was only checking out options I never went back to him, but finding the belt and the bearings is not an issue from the research I've done. Perhaps if you supplied the belt and bearings he would offer a price, at least he's UK based.
No affiliation to any of the above.
ATB Smile
Diddi
PostPosted: Fri Dec 08, 2017 4:34 pm    Post subject: Reply with quote
All,
decgraham ask:.........But isn't Diddi (d964@gmx.de ) offering a rebuild service too?
Yes, what do you need parts (kit) or complete revision - just email D964@gmx.de
--> only original parts from BOSCH,CONTI, INA, FAG...........
Goto page 1, 2, 3  Next
Page 1 of 3
