997 : 2004- 65
Boxster : 1997- 31
Macan : 2014- 6
ras62
PostPosted: Sun Jul 09, 2017 3:51 pm    Post subject: Reply with quote
Sounds like the DME relay to me although I know you've swapped it. Go round each item in the central electrics and reseat them all. This could be two unrelated problems, it sounds like the misfire issue maybe solved.
PostPosted: Sun Jul 09, 2017 5:03 pm    Post subject: Reply with quote
Flahp1 wrote:
Thanks again ras62. I was out in the car this morning, couple of hours with no problems whatsoever. Stopped a couple of times, engine turned over very quickly and fired up every time. Went out again later and when I went to start car up, absolutely nothing there, almost like there was no battery connected. Couldn't find anything obvious, fiddled around with the jump leads from the engine to the frame, swear I heard a click, it then fired up as good as ever. Very odd, any ideas? Relay? Starter motor was changed last year.
That was exactly the fault I had and a new earth strap from battery to chassis fixed it. Thumb
The game's afoot. It's time to put a bit of (Colini) stick about......Why RUF when you can WUF
Goto page Previous  1, 2
Page 2 of 2
