997 : 2004- 72
996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 10
Cayenne : 2003- 4
Beej160
PostPosted: Tue Jun 27, 2017 1:07 pm    Post subject: Massive white smoke - AOS or bore scoring? Reply with quote
Hi guys
I need your help.
Driving along on Sunday and massive white smoke appears out of both exhausts. Smells of oil although looks a lot like steam.
Pull over, towed home, now deciding on what it is where to send it to.
Started engine and tried to pull oil cap off, impossible. Stopped then unscrewed oil cap, started engine and only feel a slight vacuum.
Engine sounds OK to me. What do you think it could be?
Current - 1990 E34 M5 3.6, black/black leather, 5-speed manual
Ex - 2004 996 C4S tip coupe, seal grey, black leather
Martin996RSR
PostPosted: Tue Jun 27, 2017 1:35 pm    Post subject: Reply with quote
That's AOS, and exactly the same symptoms I had when mine went. Don't run the engine any more until it's fixed as the oil is getting sucked out of your sump and into your inlet tract in massive quantities. It can be enough to hydraulically lock a piston and bend a con-rod and you'll be into major expense if that happens.
Pay a Porsche indie to replace it for you unless you're a masochist with the arms of a four year old.
GT4
Nordschleife
Nordschleife
PostPosted: Tue Jun 27, 2017 1:36 pm    Post subject: Reply with quote
What is the state of the coolant header tank contents?
Beej160
PostPosted: Tue Jun 27, 2017 2:12 pm    Post subject: Reply with quote
Thanks Martin, I suspected the AOS too.
Anyone else out there who thinks it's something else?
GT4 - the coolant looks fine and at the correct level.
Reims
PostPosted: Tue Jun 27, 2017 6:32 pm    Post subject: Reply with quote
Agree
I have actually seen a Boxster hydraulic because of a failed AOS .. VERY messy !!
At an Indy these days !
IanG1
PostPosted: Tue Jun 27, 2017 7:33 pm    Post subject: Reply with quote
Definitely sounds like the AOS, had similar symptoms on my boxster before I changed it out. Make sure you clean out all the intake and the throttle body. I changed my AOS but didn't do this and it continued to smoke and after going back in and stripping the intake I could see why it was full of oil. Cleaned out and no more smoke.
Beej160
PostPosted: Tue Jun 27, 2017 8:49 pm    Post subject: Reply with quote
Thanks for the replies guys. I've booked it in with my indy, will be a few weeks before he can see it so will update with the result.
Cheers!
Halcyon
PostPosted: Wed Jun 28, 2017 2:57 pm    Post subject: Reply with quote
bring fat wallet.. It's pretty much an engine out job for the 'tip Sad
Unless you know Mr Tickle Hand
996.2 Carrera 4 Convertible Tip
Beej160
PostPosted: Wed Jun 28, 2017 3:17 pm    Post subject: Reply with quote
Lol, the fat wallet is soon going on a crash diet!
Beej160
PostPosted: Fri Jul 14, 2017 8:01 pm    Post subject: Reply with quote
So £750 lighter, the AOS is replaced and all is well!
Marky911
PostPosted: Fri Jul 14, 2017 8:40 pm    Post subject: Reply with quote
Good result. Bit of a bill but could be worse. Thumb
Beej160
PostPosted: Fri Jul 14, 2017 8:51 pm    Post subject: Reply with quote
It was all worth it, driving back home Smile
nigel99
2009 Porsche 997 Carrera 2S
PostPosted: Sat Jul 15, 2017 11:14 am    Post subject: Reply with quote
It's funny really that we think any bill less than a grand is getting away with it! What a lucky bunch we are.
Glad the cars sorted.
Current: 2009 997.2 C2S
Previous: 2008 Cayman 2.7, 2002 Audi TT, 1999 BMW 318!
Beej160
PostPosted: Sat Jul 15, 2017 11:17 am    Post subject: Reply with quote
My implication was that once I got back behind the wheel again after 2 weeks off the road, the pleasure it gave me was worth the pain, even as that bill was pretty painful, trust me!
