997 : 2004- 89
996 : 1997-2005 41
993 : 1993-1998 6
Boxster : 1997- 16
Macan : 2014- 0
ballcock
1996 Porsche 993 Carrera 2
PostPosted: Wed Jun 21, 2017 11:29 pm    Post subject: Help! ... New Brake Pads for 2013 Cayenne. Reply with quote
Hi all,
My wifes Cayenne is displaying 'brake pads worn' on the dash (pretty freaky and tech-tastic to me, a 993 guy!)
My question is where do I get OEM pads .. The car is under warranty so they need to be genuine Porsche items (I assume OEM will work too!)
Thanks in advance
Barney.
'83 W460 LWB G Wagen updated with OM602 engine and 6 speed 'box ...My daily driver
Ex. '99 996 C2 manual coupe.
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Jun 21, 2017 11:33 pm    Post subject: Reply with quote
OPC?
ballcock
PostPosted: Thu Jun 22, 2017 9:06 am    Post subject: Reply with quote
Local indie would be MUCH cheaper...
Zorro
PostPosted: Thu Jun 22, 2017 2:45 pm    Post subject: Reply with quote
Just had my pads done all round (2011 model) and the OE pads were Textar, others were significantly cheaper, but not OE. I similarly am running a warranty. Don't for get to buy the sensors, they come separately at £14 a piece. Not sure of the pad manufacturer for your year. It's not a DIY job unless you have some large star shaped Allan key type tool. Best check your discs for tolerance as well.
PostPosted: Thu Jun 22, 2017 4:27 pm    Post subject: Reply with quote
I very much doubt an OPC would spot non genuine pads. Unless you're anticipating a warranty issue on the brakes/discs OEM will work. Mine didn't and I changed the discs as well Grin
Would an OPC decide to get a Colini stick out and check to the level of detail to see if every consumable part was genuine before say tackling a warranty claim on the gearbox Dont know
You could buy across the parts counter at OPC and get some sap to fit them, or DIY as its easy Thumb
PostPosted: Thu Jun 22, 2017 6:36 pm    Post subject: Reply with quote
As long as the pads are black and have no obvious writeing on them to indicate they are none Porsche that can be seen when fitted then they will pass a 111 point check .
For discs then they need to be the same shape on the hub .. and grey .
We dont take things appart to check for none porsche .. we just look for the obvious !
At an Indy these days !
ballcock
PostPosted: Thu Jun 22, 2017 7:06 pm    Post subject: Reply with quote
Thanks for all the above, guys
so just to confirm that textar are the OE brand, including 2013?
Unfortunately any of the online sellers show pics with textar stamped on the pads!
Demort, are there any marks on the Porsche branded items?
Thanks!
PostPosted: Thu Jun 22, 2017 8:05 pm    Post subject: Reply with quote
Just black on the back of them , you cant see much of them to be honest .. we look for anything different from what we are used to .
We only get 1.5 hours to fully inspect the vehicle and with bonus then it tends to be quicker Wink
Nothing to stop you painting the pad back with black paint you know Smile
Edit ..
Just to say .. thats what i used to do ... not at OPC these days , moved on to pastures greener !
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Thu Jun 22, 2017 8:21 pm    Post subject: Reply with quote
Euro Car Parts sell Textar pads, not sure they do them for Cayenne you would need to check, I have just fitted them to my 997.
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
ballcock
PostPosted: Fri Jun 23, 2017 8:58 am    Post subject: Reply with quote
Thanks again folks!
