Speed Camera Warnings on 991.2 PCM and other PCM tricks
Lasrblueexige
18 Sep 2016
52
This journey of discovery came about because I had driven a friends 991.1 Cab in the US and I recall he listened to Internet Radio through out the whole journey on his PCM...they played just music without any interruptions, my ideal type of radio station.
I had not found this functionality on my 991.2 T4S so the challenge was to wade through the instruction manual and get it working. Well after a frustrating 30 minutes, I was none the wiser although I had noticed that there was an Apps Icon on the Home Screen. When I tried to select this it said that I needed to Register with Porsche Connect.
Well I thought I already had this as I have an App on my iPhone which tells me were my car is parked, if the wing mirrors are in or out, trip stats and fuel status. To be honest it is a bit of a Chocolate Fireguard and have never really used it. I then popped into the App Store and discovered there are actually two Porsche Apps, One called PCM Connect and the other, which I had, called Porsche Car Connect.
So I downloaded this and connected the iPhone to the car and hey presto a number of apps appeared on the PCM after I had selected Apps from the Main Screen. The App allows you to pass Calendar Appointments, Contacts, Photos and Destinations, based on selecting a location on the app, to the PCM. This will also help when definingIn addition, if your Car in connected to the Internet with a Sim Card you can also access Internet Radio Stations.
As part of the PCM Connect App Setup on my iPhone I also noticed that there is a Web Portal to go along with this App. This I registered for and after accessing it, discovered I could upload Personal POIs and groups of POIs to the site which are then downloaded onto the PCM. This functionality makes the loading of speed camera POI files to the PCM a reality. In addition, the PCM itself has the capability of associating a proximity warning to different POI types and this could be set for Speed Cameras if you so chose.
I can't claim I discovered this completely on my own as I was significantly aided by a post on Porsche Club GB. Here is the link to the instructions;
https://www.dropbox.com/s/9fk5hb16p...a warnings to the New Porsche PCM 4.docx?dl=0
Please read
This will also help when defining stop overs in Tours. Using the App you can point to the stop overs on the App map and save them each as a POI , say POI A, POI B etc up a maximum of 8. Send those to the car and then create a Tour and load each of the POIs you have created, starting with the destination and working backwards.
I wrote this article for the Porsche club GB 991 Register after installing it on my 991.2 GTS. Please be aware, to download the speed camera database upgrades from the Pocket GPS world you need to sign for a yearly subscription of £19. Well worth it, you will get the updates then as well.
So just to confirm, I should be able to connect my phone up to the car wifi in order to use the PCM Connect app and I don't need a data sim in the car to do this? Sort of works, but the phone keeps falling off the car wifi... sometimes throws a login dialog but that just sits and spins? Then when I go back to wifi it's gone back to my home hub not the car....
Ok. I'm still not sure I get the wifi connection to the car, but I did manage to load the speed camera POIs to the car and they showed up on the map. All good!
I then decided I didn't want the mobile ones as they are unlikely to be there versus fixed units so I unchecked those but they still show on the map. Is importing POIs a one way action? I hope not! Surely there is a way to delete them or at least dwctiveate them?
What am I missing?
#update. So it looks like I had to deactivate them on the connect portal and redownload the smaller set of POIs to only get the fixed cameras showing. Seems very counterintuitive to me!
Glad they are gone though as far too many mobiles to take notice of them. I still seem to have loads of other POI's showing though... like golf clubs and car parks which I don't remember searching for and which are unchecked. Doh.
124,558
1,441,499
48,970
Bristolsparks
