997 : 2004- 85
996 : 1997-2005 47
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 19
Cayman : 2005- 12
Macan : 2014- 1
charandhindsa
PostPosted: Mon Jun 19, 2017 8:56 am    Post subject: 996T - anyone running 19's in/around Virginia Water area?? Reply with quote
Hi Chaps,
A 19" wheel is under serious consideration for my 996Turbo - most likely 8.5/12x19 with the suitable offsets..
Anyone around Virginia Water +10/15 miles running a similar setup on their car? Especially interested in taking a look at standard suspension; height, stance, general look when combined with a 19' wheel..
Many thanks,
BlackTurbo
PostPosted: Mon Jun 19, 2017 11:14 am    Post subject: Reply with quote
Not sure if this helps but I run 19s on mine with 305 width tyres at the rear.
The compromise however is the ride which is harsher as you would expect due to the lower profile tyre.
Pics below of the look.
K9ng
PostPosted: Mon Jun 19, 2017 12:04 pm    Post subject: Reply with quote
Mine on 19" 305-30-19 on the rear 235-35-19 fronts.
I think the car needs lowering to get the desired stance,
19" will accentuate the gap even more so than 18" due to different profile tyres.
996tt Techart GTS 2
baldguy
PostPosted: Mon Jun 19, 2017 12:17 pm    Post subject: Reply with quote
Heres my 4s from years ago with 12" rear and 9" front BBS CHR's.... standard suspension etc.....
Harv
PostPosted: Mon Jun 19, 2017 10:01 pm    Post subject: Reply with quote
I don't think you can beat the look of 19" LM's with slight lowering on the 996 wide body cars
charandhindsa
PostPosted: Tue Jun 20, 2017 8:24 am    Post subject: Reply with quote
Morning Chaps - that's good insight many thanks.
@Harv - it's a classic look, pricey for me....would love to find a second hand set....any ideas?
@Baldguy - the CHR's present good value for money in my opinion. Only slight drawback is the weight over hollow spokes, but given the larger diameter and the mono block config..inevitable..I am currently considering these wheels actually - 235.35.19 8.5j et51 / 295.30.19 12j et45 running Pirelli P Zeros. Only concern being slight overall height increase ~5m front / ~10m rear. Slight rake doesn't bother me much...but again, not seen these on in person :-/
@K9ng - Michelin's? Lowered springs? Lowering may be an option in the future, but not at present. I guess I am now at the stage where aesthetics are secondary to basic form and function. Then again if the wallet allowed for a set of coilovers I'd be on them like a shot!
@BlackTurbo - great thanks. What suspension are you running?
This musing has only come about given my initial plan to refurb the hollow spokes and space out the wheels to emulate a GT2 look. ~5-600 outlay..The CH-R's (second hand, are coming in at £18oo in near new condition)
PostPosted: Tue Jun 20, 2017 8:28 am    Post subject: Reply with quote
WOW Surprised
Envy
Harry-996tt
PostPosted: Tue Jun 20, 2017 9:22 am    Post subject: Reply with quote
This is mine on 19" BBS LM's
 Filesize:  101.85 KB
 Viewed:  4929 Time(s)
Harry-996tt
PostPosted: Tue Jun 20, 2017 9:23 am    Post subject: Reply with quote
And another....
 Filesize:  385.19 KB
 Viewed:  4927 Time(s)
charandhindsa
PostPosted: Tue Jun 20, 2017 10:11 am    Post subject: Reply with quote
@Harry-996tt
Looks good.
Standard suspension? Are in in the area at all?
Stubbsy996
PostPosted: Tue Jun 20, 2017 12:10 pm    Post subject: Reply with quote
Those BBS LM's are a great looking wheel on the 996t Thumb
Harry-996tt
PostPosted: Tue Jun 20, 2017 12:19 pm    Post subject: Reply with quote
charandhindsa wrote:
@Harry-996tt
Looks good.
Im on Bilstein PSS10 suspension which is ride height adjustable and i have it sitting quite low.
Unfortunately im about 1.5 hours away from you although do attend some of the london porsche meets from time to time.
K9ng
PostPosted: Tue Jun 20, 2017 1:03 pm    Post subject: Reply with quote
Yes on Michelin Pilot Supersport, Bilstein PSS10 coilovers.
BBS CH-R 12x19 rear & 9x19 fronts.
996tt Techart GTS 2
BlackTurbo
PostPosted: Tue Jun 20, 2017 2:18 pm    Post subject: Reply with quote
I am running on designtek 30mm lowering springs.
TwinBoost
PostPosted: Tue Jun 20, 2017 2:30 pm    Post subject: Reply with quote
You guys had any front diff issues?
I'm looking at moving to 19s too and am concerned that I might upset the diff.
This thread seems to suggest that as long as the rears have a 0-2% larger rolling radius there will be no issue.
http://911uk.com/viewtopic.php?t=87956&sid=68eaaa1f61122e40b2bbf0c3fb0cd3e0
9e30 996 Turbo - Speedtech X-Pipe
TwinBoost
PostPosted: Tue Jun 20, 2017 2:31 pm    Post subject: Reply with quote
PC PC
diverzeusy
PostPosted: Tue Jun 20, 2017 10:58 pm    Post subject: Reply with quote
Here is mine on OZ HRT's centre lock look and standard suspension.
 Filesize:  607.12 KB
 Viewed:  4733 Time(s)
 Filesize:  397.65 KB
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Wed Jun 21, 2017 12:43 am    Post subject: Reply with quote
They ride well on 18" wheels. How do you feel the drive is improved by going larger?
diverzeusy
PostPosted: Wed Jun 21, 2017 7:12 am    Post subject: Reply with quote
I found the ride a little, a very little harder/more feel of the road, but the handling when pushing on at track day's is transformed compared to 18's with larger side wall tyres.
when I changed wheels I also went from Pirrelli to Michelin PS2's, which again I found a vast improvement in the wet, slight improvement dry.
As for the diff, no issues at all only slight issue on my change was the rear clearance on the inside edge just tickling the arch liner, so I 'adjusted' the liner mounting bracket.
charandhindsa
PostPosted: Wed Jun 21, 2017 8:48 am    Post subject: Reply with quote
those wheels look great Smile thanks mate.
Again. just to reiterate the thread purpose - anyone in and around the area (Virginia Water +/- 15m) with 19's / standard suspension ?
