997 : 2004- 74
996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
Gurmot
PostPosted: Sat Jun 17, 2017 12:03 pm    Post subject: 996 C2 coupe rear panel removal - to get to relays Reply with quote
Can anyone point me to a simple to removing the rear panel to get to the relays? I am diagnosing a non-running Ac compressor and want to get at the relay.
Thanks Simon
July 2002 C2 Tiptronic with M030.
Demort
Estoril
PostPosted: Sat Jun 17, 2017 3:18 pm    Post subject: Reply with quote
Picture bellow might help .. its just a foam carpet that pulls out .
You dont need to remove the seats .
997 but pretty much the same .
996 with it removed
 Filesize:  303.77 KB
 Viewed:  788 Time(s)
 Filesize:  185.12 KB
 Viewed:  794 Time(s)
Gurmot
PostPosted: Sat Jun 17, 2017 3:36 pm    Post subject: Reply with quote
Thanks for the pictures. I have tried to pull that piece out but it didn't want to budge. Is it held in with clips or Velcro?
Demort
Estoril
PostPosted: Sat Jun 17, 2017 3:38 pm    Post subject: Reply with quote
The carpet is a bit rigid and is under the side panels so i tend to lift it from the front and in the middle then slide it out from each side panel in turn.
Nothing locateing it though .
Easy job to show you .. not so easy to explain .. sorry .
At an Indy these days !
Gurmot
PostPosted: Sat Jun 17, 2017 3:40 pm    Post subject: Reply with quote
Thanks again. I will give it another try Smile
