997 : 2004- 74
996 : 1997-2005 46
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
Rioja996TT
PostPosted: Sat Jun 17, 2017 8:52 am    Post subject: Brake pad wear dash light Reply with quote
I have an intermittent fault which shows the above dash warning light for a few days and then disappears. There is no problem with the pads and I have been told that cause may be a hardened wiring harness under the passenger wing. Can this be repaired/replaced without great difficulty?
Shanghai
PostPosted: Sat Jun 17, 2017 3:30 pm    Post subject: Reply with quote
I assume the brake pad sensor wires have all been checked and found to be ok ?
The harness is encased in a hard plastic so a replacement is pretty much whats needed .
The n/s/f isnt too bad .. its closer to the ABS cu so less panels to remove .
There are however 4 of these ( 1 on each corner ) so again i assume its actually been checked and found to be open circuit ? other wise its just a guess .
At an Indy these days !
Rioja996TT
PostPosted: Sat Jun 17, 2017 4:52 pm    Post subject: Reply with quote
Yes it was diagnosed as front left harness about three years ago, but then the fault disappeared until the last few weeks. Is it a time consuming job?
Shanghai
PostPosted: Sat Jun 17, 2017 6:03 pm    Post subject: Reply with quote
Been a long time since i replaced one but i think its about 1 - 1.5 hours .
Rioja996TT
PostPosted: Sun Jun 18, 2017 10:29 am    Post subject: Reply with quote
Thanks! I have a funny feeling that as soon as I buy the part, the light will go out again!
