996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
Oldboy
PostPosted: Thu Jun 15, 2017 2:28 pm    Post subject: Alarm Reply with quote
Needed to take the battery out to clean the tray as it has abit of corrosion on it.According to handbook the alarm is disarmed when you disconnect the leads from the battery.So l am standing there with both leads in my hands and the alarm is going off.What am I doing wrong?.
Gurmot
PostPosted: Thu Jun 15, 2017 2:38 pm    Post subject: Reply with quote
I think the standard procedure is to insert the key in the ignition before disconnecting. The alarm has a battery back up and inserting the key disables it.
July 2002 C2 Tiptronic with M030.
PostPosted: Thu Jun 15, 2017 2:43 pm    Post subject: Reply with quote
Insert the key and turn it to position 1 before disconnecting the battery - negative terminal first.
ps. The other thing you did wrong was posting your question in the 'Meets and Events' section. Very Happy
Oldboy
PostPosted: Thu Jun 15, 2017 4:39 pm    Post subject: Reply with quote
Thanks for info,
As soon as I pressed send I realised what I had done,senior moment.
