997 : 2004- 66
996 : 1997-2005 34
964 : 1989-1993 1
Cayman : 2005- 20
Emmjayeff
PostPosted: Thu Jun 15, 2017 1:53 pm    Post subject: High pitched whine on my 1990 964 C4 Reply with quote
I have a whine which appears to be coming from the front of the car but I couldn't say for certain. It seems speed sensitive and is louder when I accelerate and disappears when I dip the clutch. It is more noticeable at slower speeds and either disappears when I get to around the 100kph mark or the increased noise masks the sound, I suspect the former. In neutral with the car stationary there is no whineing noise. Any ideas what the problem might be? All suggestions gratefully received.
ColinC
PostPosted: Thu Jun 15, 2017 2:13 pm    Post subject: Reply with quote
I have a similar 'whine' which occurs in the same circumstances when my wife is in the passenger seat!
Emmjayeff
PostPosted: Thu Jun 15, 2017 2:38 pm    Post subject: Whineing noises in a 964 Reply with quote
You're lucky, I can't even get my wife into the car, something about it being too old, at least I think she means the car!
Emmjayeff
PostPosted: Thu Jun 15, 2017 2:44 pm    Post subject: Whineing noises in a 964 Reply with quote
Chief
PostPosted: Thu Jun 15, 2017 6:55 pm    Post subject: Reply with quote
Could be the front diff Question Or even the prop shaft Question
- 964 C2 The Red Baron - 914 2.0 Project Blue Book - Cayman S Sport Edition Amber Alert! -
Instagram - @chiefporsche
Emmjayeff
PostPosted: Thu Jun 15, 2017 7:06 pm    Post subject: Whine on 964 Reply with quote
Thanks for your suggestions. Perhaps I should have mentioned that I have just had the aircon regassed and I believe that an incorrect pressure can cause a whine. Has anybody any experience with the aircon causing this?
I'll check the front diff and prop shaft with my specialist if I don't find a simpler solution, fingers crossed.
PostPosted: Thu Jun 15, 2017 9:05 pm    Post subject: Reply with quote
Turn the AC off and see if it still does it. However if it was the AC surely the noise would come from the compressor which is in the engine bay?
Only thing up front in the wing is the condensor and hi-low speed electric fan.
I'm with Chief thinking it could be a drive shaft/diff given its a C4 and the noise is when torque is being applied Question
The game's afoot. It's time to put a bit of (Colini) stick about......964/993 wanted. Cash waiting. No dreamers
Emmjayeff
PostPosted: Fri Jun 16, 2017 6:57 am    Post subject: 964 whine Reply with quote
Thanks for the responses. It looks like I will have to take the car down to Barcelona to the specialist there for them to check it out for me. At least the car will stay cool getting there. I'll go out for another run today to see if I can isolate it it any better.
Mike
