996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
Scubadiver
PostPosted: Tue Jun 13, 2017 9:03 am    Post subject: Parking sensor fault Reply with quote
One last thread (for now!) while I try and sort out the niggles on my new purchase Laughing
2003 Cayenne Turbo. The parking sensors (front and rear) seem to have a bit of a mind of their own. Sometimes they work normally, at others they display the red lights and beep as if I'm about to hit something, even when there's nothing around (like having just slowed down to turn a corner for instance)
Are there any common issues where I could start?
Shanghai
PostPosted: Tue Jun 13, 2017 6:32 pm    Post subject: Reply with quote
Yup a few places ..
If they go red then its normally because a fault has been registered .
Check the sensors .. are any pushed back at all.
Are any very dirty or anything obstructing them .. tow bar for example .
The main wireing plug is suspect on these .. its in an area that gets an awfull lot of dirt and water on it .. the rear is from memory n/s/r in the corner of the bumper and can be reached from underneath .. cant rember the front but its going to be similar i would have thought .
Have a good look at these connections for corrosion to the pins.
Other that that then you need a tester on it to see whats failing .. normally a single sensor and there will be a code for which one , ie FRI front right inner , FRO front right outer etc .
Another common fault on these im afraid .
At an Indy these days !
Scubadiver
PostPosted: Tue Jun 13, 2017 7:54 pm    Post subject: Reply with quote
Thanks buddy, I did check and clean all the sensors, because it's intermittent I like the sound of the main wiring plug and potentially rusty pins, I'll check that out tomorrow. Spot on.
Now tell me, when you park up and walk away from your car and hear a psst then look round hear another psst and see the rear suspension raise itself up, that's normal right? Laughing
Shanghai
PostPosted: Tue Jun 13, 2017 8:01 pm    Post subject: Reply with quote
yes and no .. i dont tend to park these cars very often Very Happy
They do settle as the car lvls its self .
ANY fault on air suspension will log a code pretty dam quick .. its more of a problem if its lower at one corner when you come out in the morning .
The lvl compressors are prone to failure , they over heat and will give a fault code of 1772 pressure sensor .. its not that its the compressor thats at fault .
I replaced one last week Smile
Webasto make them .
9 pm .. time to go .. till tomorrow at 7pm then Very Happy
Scubadiver
PostPosted: Tue Jun 20, 2017 9:05 am    Post subject: Reply with quote
Ah, missed our appointment Laughing
Seems normal that air suspension adjusting, took me by surprise the first time I noticed as I'm not used to cars having a mind of their own after you've parked up and walked away, but it appears to just want to settle itself.
I popped my head under and can see the connector you're talking about for the parking sensors but haven't taken it apart yet due to other pressing matters. Good call though as it seems pretty much OK now the weather has been dry for a while so I reckon you're spot on again Wink
I'll get to it after I get back from holiday, at least nothing can go wrong in the meantime!
Shanghai
PostPosted: Tue Jun 20, 2017 6:55 pm    Post subject: Reply with quote
Lol .. ill save my list of things that can go wrong till after your holiday .. i dont want to put you off a good time Very Happy
Dont worry though its not all bad but things that are worth checking in the future Smile
Scubadiver
PostPosted: Tue Jun 20, 2017 9:32 pm    Post subject: Reply with quote
Thanks mate, definitely a list I want a look at. Always good to know the commonly occurring problems (especially at the side of the road!)
And I wouldn't want to run out of bits to fiddle with Laughing
Satch
PostPosted: Sun Sep 03, 2017 1:12 pm    Post subject: Reply with quote
Not sure if you ever got this sorted but the NT510 kit will allow you to find faults in the parking system (most likely sensors)
http://www.diagnostic-world.com/pages/Porsche_Multi_System_Diagnostic_Kit_Foxwell_NT510_Engine_ABS_Airbags_Oil_Service_etc__212707-z=656037&p=121453.cfm
Thanks.
Porsche 911 997 C4s Speed Yellow
Porsche 986 Boxster 2.7 Arctic Silver
Porsche 911 991 C2S Carrera White - Sold
Porsche 911 996 Rainforest Green - Sold
