996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
DucatiRob
PostPosted: Tue Jun 13, 2017 8:19 am    Post subject: GT3/ Aerokit Bumper Reply with quote
Found this on Teile:
https://teile.com/en/porsche-parts-shop/model-911-997/15/Body-parts/802A-Front-bumper/44/802-00-Front-bumper-Aero-Kit-CUP/Aero-Kit-CUP-GT3-Look-front-bumper-covering-with-headlight-washer-system/4100
Have been looking for a GT3 fount bumper for a while, seems like good value? Most I have seen on eBay are around £1k for second hand OEM items, mostly with some damage, or fibreglass items from Eastern Europe!
This is described as 'GT3 look', any idea what the difference might be? Also, what other bits might I need for fitting?
Cheers Thumb
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
Alfaian
PostPosted: Tue Jun 13, 2017 9:45 am    Post subject: Reply with quote
I'd say it's because of copyright laws. Probably exactly the same look when on the car.
Minus Porsche tax of course.
You'll need the rubber lip by the looks and shouldn't it fit straight on Dont know
Sorry can't be any more help but that would look great on the car rob Cool
Arctic silver C2S
Robx
PostPosted: Tue Jun 13, 2017 12:50 pm    Post subject: Reply with quote
Looks like a decent price! You'll also need the left and right grill frames so that the inlets marry up to the radiators. Got mine from Porsche parts, think they were about 60 quid. You can swap the centre panel from the old bumper to the new one. I picked up a new one for about £30 from ebay a couple of weeks back as a spare. You'll also have to swap a couple of the fixings over, these were pretty easy, just drill off from the old bumper and rivet to the new one. I made some grills from mesh brought of ebay, best to install them when the bumper is off as its a pain to do once on the car. I can provide part numbers/pics and links if needed.
elliot_holder
PostPosted: Tue Jun 13, 2017 2:06 pm    Post subject: Reply with quote
Tiele.com only sell OEM parts as far as I'm aware.
And that looks like a genuine Aerokit number.
Difference between it and a GT3 number is the 'smile' grill. Aero kit doesn't have this and therefore doesn't come with the support bracket fitted.
Doesn't stop you retrofitting one tho.
DucatiRob
PostPosted: Tue Jun 13, 2017 3:48 pm    Post subject: Reply with quote
Thanks guys. Fairly sure these are OEM parts on Teile, they also sell the side vent frames for €27 each, if the centre frame is a straight swap then that would be great! Thumb
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
PostPosted: Tue Jun 13, 2017 4:20 pm    Post subject: Reply with quote
Rob, they only sell genuine parts the reason they say gt3 style is because its a genuine aero kit bumper not a GT3 one the difference is the smille grille as other have said . Its a good price .
as RoxX says you need to change the grille attachments left and right ctr is the same and you can use the blank plate if its a man or the grille surround if its a tip or has 3rd rad fitted.
you will also need the lower lip , mate buy original or at min Plastic not GRP and get the gt3 one not the cup one (no twin air flow holes) as its deeper and will catch on everything.
DucatiRob
PostPosted: Tue Jun 13, 2017 8:43 pm    Post subject: Reply with quote
Cheers Phil Thumb Thinking this will be my next project whilst I consider what to do with my Turbo wing and find a different solution for the air box!
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
Dexterich
PostPosted: Tue Jun 13, 2017 9:46 pm    Post subject: Reply with quote
Hi Rob. I recently fitted the aerokit front PU, bought it from Porsche notts at £911.81 (yes really - I didnt make that number up!) - looks exactly like the Teile i.e. Porsche OEM. This included the lower lip and everything needed to fit it - they even shipped it to the paint shop for me. I reckon that one you spotted is £725 + shipping, say £75 + lower lip which I think is about £200 = £1000.
It maybe worth checking what they include in the box, if it's everthing then its a good deal.
C2S, Black, Tiptronic
PostPosted: Tue Jun 13, 2017 10:00 pm    Post subject: Reply with quote
Rob, worth the call mate as the lower lip is £200 the vent surrounds another £60 the pair so yes running close to 1k if the opc is cheaper for everything its a no brainer. Thumb good call Dexterich Thumb Thumb
DucatiRob
PostPosted: Tue Jun 13, 2017 10:10 pm    Post subject: Reply with quote
Ch eers guys, I am fairly certain its is the bumper only as they sell all the other bits too! But will check first before I order!
Worthwhile checking Porsche prices too then! Thumb
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
robbiej
PostPosted: Fri Jul 14, 2017 9:17 am    Post subject: Reply with quote
they just sprayed this at the Independent and really they should have stripped it down as there is micro cracks even though its a new part.
I purchased new skin, splitter, side brackets and grills all from teile around 1200euros landed
DucatiRob
PostPosted: Fri Jul 14, 2017 11:32 am    Post subject: Reply with quote
Micro cracks? I am guessing they probably come primed but they will still need to be rubbed down and well primed again before base and top coat! Maybe they over heated it to cure, new paint is pretty flexible so it would be unusual for cracks to appear so soon! Will they re-do it for you?
I will be painting mine myself, the paint I had mixed for my wing/decklid is a perfect match so I am more confident now to paint the front end Thumb
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
robbiej
PostPosted: Fri Jul 14, 2017 11:58 am    Post subject: Reply with quote
looks like they are re-painting but painter claimed it was because they were pattern parts which they are not. The indi is fighting the corner
looks like a complete rub down is in order....
DucatiRob
PostPosted: Fri Jul 14, 2017 9:30 pm    Post subject: Reply with quote
Sounds to me like they haven't prepped it properly and used a good quality primer that would have a flex additive. I'm not sure if these parts are pre primed, even if they are they would still need to clean thoroughly, wet sand and apply a good coat or two of primer.
Are they a decent body shop outfit?
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
robbiej
PostPosted: Mon Jul 17, 2017 1:05 pm    Post subject: Reply with quote
we will see...
DucatiRob
PostPosted: Fri Jul 28, 2017 1:34 pm    Post subject: Reply with quote
Just getting prices sorted for the bumper now form Porsche Notts! Quite a choice of spoiler lips, is the Aerokit one that much lower that the GT3? I do quite like the one with the vents in but a bit concerned as my next mod will be lowering with Ohlins R&T!!
Any pics people have would be greatly appreciated Thumb
Are there any decent aftermarket spoiler lips available in rubber?
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
DucatiRob
PostPosted: Tue Aug 01, 2017 3:39 pm    Post subject: Reply with quote
I got a price from Porsche Notts but not cheap! £2,200 for just the bumper Surprised
They did say that the part number I'd quoted was not the one supplied recently! I'd asked for P/n 99750596109 which is priced at 832€ on the Teile site!
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
Dexterich
PostPosted: Tue Aug 01, 2017 9:42 pm    Post subject: Reply with quote
Hi Rob, part number I bought from porsche notts was 997.044.802.32 "front apron aer" £799.84 +vat. Everything I needed in the box, although there was no discussion on options for the lower lip (it has one vent either side).
Just guessing that your part maybe genuine gt3 and not aero - although I cannot see a difference?
DucatiRob
PostPosted: Tue Aug 01, 2017 10:16 pm    Post subject: Reply with quote
Thanks for this Thumb I will check it out. The item I quoted the number for is definitely just and Aero and doesn't have the smile vent like the GT3, according to the Teile site anyway!
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
DucatiRob
PostPosted: Wed Aug 02, 2017 7:40 pm    Post subject: Reply with quote
Confused.com Dont know
Can't find that par number on Teile bust have found it on Design911 at £919 + VAT. Same with all the bits including spoiler!
http://www.design911.co.uk/fu/prod13820/Front-Bumper-with-Lower-Spoiler-Aero-Porsche-997-2004-08--OE-Part-No-99704480202---99704480203-99704480232/
The also have this:
http://www.design911.co.uk/fu/prod2323/Front-Bumper-Aero-Porsche-997-2004-08--OE-Part-No-99750596100---99750596101-/
Looks exactly the same, but is just the bumper only without the spoiler at £1,856 + VAT (oddly cheaper with headlamp washer than without!). This also has the same part number as the one on Teile that is only 832 Euros!!
https://teile.com/en/porsche-parts-shop/model-911-997/15/Body-parts/802A-Front-bumper/44/802-00-Front-bumper-Aero-Kit-CUP/Aero-Kit-CUP-GT3-Look-front-bumper-covering-without-headlight-washer-system/14218
Anyone have any idea what the difference might be?
Carrera C2S Manual
Mercedes CLK DD
Ducati 996
