997 : 2004- 74
996 : 1997-2005 42
993 : 1993-1998 8
964 : 1989-1993 6
Classic : 1950-1965 1
Boxster : 1997- 10
Cayenne : 2003- 7
mun802
PostPosted: Mon Jun 12, 2017 7:30 am    Post subject: Left for a week and now wont unlock! Reply with quote
Hi Guys,
As per heading , I left car on trickle charge for a week and now it wont unlock with either key fob despite changing batteries in both. Drivers door will unlock manually with key and car will start but central locking and alarm no longer works.
Any thought appreciated.
Ian Perry
2004 Porsche 997 Carrera 2S
PostPosted: Mon Jun 12, 2017 7:44 am    Post subject: Re: Left for a week and now wont unlock! Reply with quote
mun802 wrote:
Hi Guys,
This happen on my 997 in the end it was the central locking unit in the passenger door [it's Volkswagen]
Also did you use the door handle first to wake up the system has it goes to sleep [997] and then use the fob.Hope this helps .
Mike!
PostPosted: Mon Jun 12, 2017 7:48 am    Post subject: Reply with quote
Sounds a bit like 'sleep mode'. Have you tried opening the door manually, and when the door is open and/or with the key in the lock try unlocking it with the fob. The thing is I would have expected the car to wake up after opening the door or starting it, worth a try I guess.
PostPosted: Mon Jun 12, 2017 7:58 am    Post subject: Reply with quote
This thread should help.
=> http://911uk.com/viewtopic.php?t=79588&start=0&postdays=0&postorder=asc&highlight=sleep+mode
mun802
PostPosted: Mon Jun 12, 2017 8:41 am    Post subject: Reply with quote
Thanks for the replies guys. I think ive tried a combination of some/ All of these albeit withot knowing but I'll try a more methodical appoach as has been suggested tonight.
dombo
PostPosted: Mon Jun 12, 2017 9:57 am    Post subject: Reply with quote
Mine did the same on Saturday. Unlock driver's door with the key, put key in ignition and turn on (just so the dashboard lights come up), then take the key out and zap, car should unlock properly.
sackerley
PostPosted: Mon Jun 12, 2017 12:13 pm    Post subject: Reply with quote
Isn't this a battery saving feature? As mentioned by others using the key manually will unlock the door. Just make sure you put the key in the ignition with 5 seconds or so to stop the alarm going off.
If memory serves this is in the manual.
1998 Artic Silver 996.1 - manual - carbon interior - Momo Protopito
mun802
PostPosted: Mon Jun 12, 2017 12:18 pm    Post subject: Reply with quote
Thats exactly what I did but the remote fob (BOTH) no longer seem to have any functionality.
Scully
PostPosted: Mon Jun 12, 2017 12:22 pm    Post subject: Reply with quote
Hmm interesting - I went on holiday for a week and expected the car to go to sleep while I was away. When I got back, sure enough the remote fob wouldn't unlock the doors - I was expecting that as I had read the manual.
However as soon as I unlocked the door manually and opened it, the alarm went off - so no 10 seconds delay.
Why would that be? Putting the key in the ignition and turning it to position 1 stopped the alarm, but I don't know why I didn't get the 10 seconds grace.
stirling
PostPosted: Mon Jun 12, 2017 12:56 pm    Post subject: Reply with quote
Mine goes to sleep after about 5 days. After that it won't unlock with the remote. If I then unlock and immediately lock the car again with the key in the lock, the remote works again.
stirling
PostPosted: Mon Jun 12, 2017 12:57 pm    Post subject: Reply with quote
toobusy
PostPosted: Mon Jun 12, 2017 1:07 pm    Post subject: Reply with quote
This is exactly what mine does and what I do. If I unlock with the key and open the door, the alarm goes off immediately...
2003 Carrera 4, KTM, Jota
Harv
PostPosted: Mon Jun 12, 2017 3:39 pm    Post subject: Reply with quote
Sounds similar to what's happened with mine.
Went away for a week and when I came back to the car the key fob no longer works. All methods to awaken the system failed other then opening the door with the key and turning the ign on before 15sec expires and the alarm goes off.
Interesting thing is I suspected the key fob went duff and replaced the battery (although it illumined the red light when pressed) but that didn't solve it so
I sent the key fob off for repair to be told that they tested it and the signal was all good and it's working well.
This leaves me to think there's an issue with the micro switch in the door handle that gives the alarm ECU signal to wake up but I've yet to confirm this as I thought also turning the ign on and pressing unlock on the key fob also awakens the alarm which on mine doesn't work either.
Interested to hear your findings.
Ultimately I will have to put it into the dealer or Indy with the diagnostics to confirm what the issue is (my Durametric won't communicate with the alarm)
Good luck with it
wizard993
1966 Singer Gazelle
PostPosted: Mon Jun 12, 2017 4:03 pm    Post subject: Re: Left for a week and now wont unlock! Reply with quote
mun802 wrote:
Hi Guys,
Take it out for drive then try locking and unlocking it.
"The smallest feline is a masterpiece"
- Leonardo da Vinci
mark pearce
Approved Trader
PostPosted: Mon Jun 12, 2017 5:07 pm    Post subject: Reply with quote
After 5 days the alarm goes into sleep mode
you then open the car with the key in the door key hole and then put the key in the ignition and turn it to position 1 with 15 seconds or the alarm goes off.
You can then use the remote as normal.
If you have problems with a key remember you can resynchronise the key by putting the key in the ignition and holding the lock button for 30 seconds to resynchronise the key
Stirlings The Low Mileage Porsche Specialists
mark@stirlings.co.uk
Tel 01736 757755
www.stirlings.co.uk
Passion for Perfection
Why risk the alternative?
Demort
Estoril
PostPosted: Mon Jun 12, 2017 6:32 pm    Post subject: Reply with quote
In case its not sleep mode then check under the passenger seat for water or water bottles.
Possibly it needs a vehicle handover which is done with a tester but i kinda doubt its that .
Another possible but rare fault is the ignition lock .. it doesnt register that the key is out of the ignition so the fobs wont work .. again a tester to diagnose that fault .
At an Indy these days !
mun802
PostPosted: Thu Jun 15, 2017 7:37 am    Post subject: Reply with quote
Thanks for all the advice guys, sadly to no avail. Cars booked in at Indy week Friday for new Key head and programming...£200!
Harv
PostPosted: Thu Jun 15, 2017 7:53 am    Post subject: Reply with quote
If you are friendly with the dealers don't forget to ask them for a discount on the key head part (normally they can do 10%) and the reduced rate for the 996 age of cars which is now a classic.
It can't be more than 15min work but I suspect 30min maybe the min labour charge time.
