997 : 2004- 93
996 : 1997-2005 44
964 : 1989-1993 4
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 8
Macan : 2014- 0
TB
PostPosted: Fri Jun 09, 2017 8:33 pm    Post subject: 997.2 PDK bleeder screw slight leak? Reply with quote
Slight leak from bleeder screw in PDK. Advised by OPC that I need a new PDK. I was able to buy a new bleeder screw ref 9G1 321 885 00. Any thoughts?
PostPosted: Fri Jun 09, 2017 8:58 pm    Post subject: Reply with quote
Can you supply any more info ? a picture perhaps as im unaware of a pdk bleeder screw .. drain bungs yes but i know of nothing that needs bleeding on a pdk im afraid .
TB
PostPosted: Sat Jun 10, 2017 9:01 pm    Post subject: Reply with quote
See snaps of bleeder screw.
Also cutaway of pdk.
 Filesize:  149.08 KB
 Viewed:  6925 Time(s)
 Filesize:  157.62 KB
TB
PostPosted: Sun Jun 11, 2017 5:16 pm    Post subject: Reply with quote
See location.
 Filesize:  144.93 KB
 Viewed:  6867 Time(s)
PostPosted: Sun Jun 11, 2017 5:51 pm    Post subject: Reply with quote
This rings a bell and i have a horrible feeling the OPC might be correct .. i think its the gear oil bung and when it leaks there it indicates that a seal has failed inside and you are getting an oil mix of the 2 fluids .
The bung in the picture has been removed before which would lean towards someone trying to fix these previously perhaps.
Now might be a good time to try and get a warrenty .
TB
PostPosted: Tue Jun 13, 2017 5:23 pm    Post subject: Reply with quote
Snaps of bleeder screw.
Any idea what it wa designed to do?
How come you can buy the part?
 Filesize:  459.39 KB
 Viewed:  6769 Time(s)
 Filesize:  448.75 KB
 Filesize:  334.09 KB
GP41
PostPosted: Mon Jul 03, 2017 8:29 am    Post subject: Reply with quote
Any updates here?
I had a leak from PDK about a year ago. I thought it was following a service where oil had been changed and overfilled. It occured after a very long journey.
The leak was cleaned up and no further issues were found but after another very long run I've found another leak. Can't tell exactly where it's coming from yet but this thread has certainly got me thinking.
How have thngs turned out?
997.2 C4 PDK
TB
PostPosted: Mon Jul 03, 2017 5:32 pm    Post subject: Reply with quote
I cleaned the area around the existing bleeder screw and applied sealant to the end and sides.
I checked it after two days and again after a few weeks later and there was no leak.
The PDK is working the same as when I got the car in March.
I have done about 6k miles.
See snap
[/img]
 Filesize:  473.25 KB
 Viewed:  6415 Time(s)
GP41
PostPosted: Mon Jul 03, 2017 5:41 pm    Post subject: Reply with quote
OK, thanks - good to know you haven't had any more trouble.
Mine's going in for investigation on Thursday. WIll see what they know at OPC about this issue that Demort mentioned.
997.2 C4 PDK
TB
PostPosted: Mon Jul 03, 2017 6:26 pm    Post subject: Reply with quote
Not sure if I want to find out the truth.
Would like to know why the bleeder screw is available to buy if it should not be changed?
Grateful for any info from your OPC visit.
Magic919
PostPosted: Thu Jul 06, 2017 7:04 pm    Post subject: Reply with quote
When mine did it they said it's a seal inside that leaks and the oil is just using that route to get out. I had the gearbox replaced.
997.2 C2S PDK
997.2 C4S PDK
GP41
PostPosted: Thu Jul 06, 2017 7:09 pm    Post subject: Reply with quote
They've confirmed that this is the source of my leak but don't know yet whether it is internal or external seal. They've ordered a replacement bung but have also sent photos off for review. I await news.....
Looks like there's a bit of a trend here!
997.2 C4 PDK
PostPosted: Fri Jul 07, 2017 6:59 pm    Post subject: Reply with quote
Sorry i lost track of this thread but the above was what i had herd through the mechanics grapevine if you like.
Not something ive come across and i have no idear what this bleeder valve is for and trust me i have searched for info on it.
From the shape then it looks like it seals two internal ports and when released would indeed act like a bleed valve but im just guessing here .
My worst assumption is it will need a gearbox .. hence my warrenty quote from much earlier im afraid .. hopefully im totally wrong though .
Magic919
PostPosted: Fri Jul 07, 2017 7:50 pm    Post subject: Reply with quote
They suggested I could keep popping back to have it topped up. I didn't fancy that and had the box replaced.
997.2 C2S PDK
997.2 C4S PDK
GP41
PostPosted: Fri Jul 07, 2017 9:35 pm    Post subject: Reply with quote
Thanks Demort.
Ive got warranty, fortunately....
997.2 C4 PDK
GP41
PostPosted: Sat Jul 15, 2017 7:30 pm    Post subject: Reply with quote
New screw getting fitted. We'll see if it cures it...
997.2 C4 PDK
GP41
PostPosted: Wed Jul 19, 2017 4:54 pm    Post subject: Reply with quote
On further inspection, new screw isn't going to solve it. New box is. They did say they'd never come across this before though so maybe not such a common problem. I'm intrigued to know how damage could have been done to a totally internal seal inside a sealed unit. Confused
Any suggestions for other work that ought to be done while transmission (and possibly engine) is out?
If I've been warned that the coupling of the cooling system are corroding (as they are well known to) is the fix for that something that requires engine out? I was sure I'd read that on here at some point. If so, it might be worth seeing whether I could sort that at the same time. I realise that usually Porsche will refuse to deal with issues that are close to being at a point of needing replacement just because it is easier and instead tend to make you wait until something has gone wrong, even if it is more costly and disruptive to do so, but it's worth a try???
Thanks for all your help so far. It's so much less stressful going into these situations with a fair understanding of likely outcome Smile
997.2 C4 PDK
Magic919
PostPosted: Wed Jul 19, 2017 5:08 pm    Post subject: Reply with quote
It's not really a sealed unit, it's more that Porsche never work on them. A ZF specialist should be able to fix one.
I don't think they dropped the engine to do my gearbox, though the reverse was certainly true.
997.2 C2S PDK
997.2 C4S PDK
GP41
PostPosted: Wed Jul 19, 2017 5:20 pm    Post subject: Reply with quote
Ok thanks. I'll see what they say.
997.2 C4 PDK
TB
PostPosted: Wed Aug 23, 2017 4:59 pm    Post subject: Reply with quote
Any update?
Goto page 1, 2, 3  Next
Page 1 of 3
