997 : 2004- 77
996 : 1997-2005 41
993 : 1993-1998 8
964 : 1989-1993 6
Boxster : 1997- 12
912-914-924-928-944-968 4
mollytherocker
PostPosted: Sun May 28, 2017 9:29 pm    Post subject: New Springs/Dampers - views on KW Variant 1? Reply with quote
Hi
The time has finally come for new spings and dampers on my 95' 993 C2.
I know this has been done to death, but I need your recommendations and experience please!
My car has the M033 option and I want it to be slightly stiffer and sharper but not rock hard!
A Porsche indy is recommending KW variant 1 as a good compromise at a reasonable cost.
Do your worst!
PostPosted: Sun May 28, 2017 9:48 pm    Post subject: Reply with quote
Koni FSD with H&R springs get a good recommend by CoG when I was enquring a while back. I think they are also cheaper than KW Dont know
Kim squared the circle and ended up with Koni I believe.
Illuminati are now going down the Porsche classic issue if you like 'On the Buses' green Rolling Eyes
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Mon May 29, 2017 12:40 pm    Post subject: Reply with quote
Eibachs match nicely with the FSDs. Pretty sure there's a pre-packaged kit with FSD and Eibachs.
Rob
'94 C2 Iris Blue (+ White Stripes!)
Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + wheels)
Range Rover Sport (L320 chipped)
Mercedes E Class (W211 chipped)
TT Roadster (standard - wife’s daily!)
mollytherocker
PostPosted: Mon May 29, 2017 9:37 pm    Post subject: Reply with quote
Thanks guys.
Anyone got the KW Variant 1 kit fitted? Or been in a 993 with it fitted?
ras62
PostPosted: Tue May 30, 2017 11:44 am    Post subject: Reply with quote
Quality? Koni are not in the same ballpark as KW / Bilstien imho.
MaxA
PostPosted: Tue May 30, 2017 11:50 am    Post subject: Reply with quote
I don't have a 993 but I suspect that if I did, it would either be running Bilsteins (which can be rebuilt) or Ohlins. If you have to run KWs, then v3s for proper adjustability.
2010 997.2 in Finnish spec: 4S, white over blue, Nokian studded tyres, always filthy.
Cameltoe & Heel
PostPosted: Tue May 30, 2017 12:02 pm    Post subject: Reply with quote
FSD's with new M033 springs should do you nicely Thumb
Trev
mollytherocker
PostPosted: Tue Jun 20, 2017 8:58 pm    Post subject: Reply with quote
Well, after much thought, research and advice I have gone with my original idea of KW variant 1.
I will update you on my thoughts once they are fitted and set up!
 Filesize:  71.26 KB
 Viewed:  2260 Time(s)
Jet Jock
PostPosted: Wed Jun 21, 2017 9:55 pm    Post subject: Reply with quote
Molly,
I have had the KW Super Sport set up(thanks Chris) on mine for some time and love them. You won't be disappointed.
JJ
993 C2, RSR's, Cargraphic 100 Cell Cat, Turbo Twist Hollows, Brembo Big Reds Turbo Brakes, Big Ovals, Wayne Schofield Remap, KW Supersport set up by Chris Franklin, RS engine and transmission mounts, Fabspeed induction kit, HID conversion...
madasasnake
PostPosted: Wed Jun 28, 2017 8:08 pm    Post subject: Reply with quote
I'll post more detail in due course but I've just picked up my car from Centre Gravity, although sadly it was in the rain!
Its the first time I've used my headlights or my windscreen wipers for years!
The difference is quite astounding.
I took their advice from start to finish and ended up with Bilstein B8s and my original springs.
I also had new OEM Track Rod Ends and I had the wishbones re-bushed with Super-Pro bushes.
I was tempted bu Kimbo's excellent research and conclusions and was leaning towards Koni FSDs until the Porsche Classics were released.
I was then very reliably informed that the "re-working" of the Bilstein as a now "preferred partner" of Porsche was limited to a green paint job, so I decided to have the Bilstein B8, which appears to be the "Classic" in all but colour!
1996 Carrera S: Vesuvius
Always carry a flagon of whisky in case of snakebite and furthermore always carry a small snake.
mollytherocker
PostPosted: Thu Jun 29, 2017 10:02 pm    Post subject: Reply with quote
All fitted today along with new;
C4 engine mounts
HT leads
Dizzy caps
Rotar arms
Heat exchanger gaskets
Windscreen washer motor
Full geometry and final set up tomorrow.
Cant wait to pick it up!
