997 : 2004- 77
Boxster : 1997- 15
Cayenne : 2003- 3
VPD255M
PostPosted: Sun May 28, 2017 11:53 am    Post subject: Titanium Brake Caliper Studs - who wants some? Reply with quote
Inspired by the manifold studs thread http://www.911uk.com/viewtopic.php?t=110603&sid=cf194aee4c03c8d15d1db3440395825b I've been in touch with Matt (Poppopbangbang) and he's going to manufacture some titanium brake caliper studs for me - he's suggested that I put a post up to see if anyone else would also like some.
My car is a 997.1 GT3 (PCCB) and the calipers are attached to the aluminium wheel uprights with Allen head bolts, using studs (as on the cup cars) does away with the single use stretch bolts that Porsche advise should be replaced each time the caliper is removed and also takes away the risk of stripping out the thread in the aluminium upright.
Matt's solution is a high quality Ti stud with a compact aero K-Nut to clear the limited diameter of the bore recess on the caliper.
For 997 GT3 & Turbo - from what I've researched the bolting dimensions for the rears are the same for both steel and PCCB 997.1 & 997.2. The fronts are common for 997.1 PCCB & 997.2 PCCB & steel only (997.1 steel are longer +15mm).
Please add your name to the thread if you're interested in a set.
997.1 GT3 CS
thecarfixer
PostPosted: Sun May 28, 2017 4:05 pm    Post subject: Reply with quote
I'd be interested in some standard 996 type ones if they can be made?
Dunno if this makes too many varieties.
I never like taking the OE bolts out!
Chris_in_the_UK
Estoril
PostPosted: Sun May 28, 2017 4:37 pm    Post subject: Reply with quote
I would be interested in a set for the Cayman (Gen. 1).
EDIT - I have PCCB's
2006 Cayman S PCCB's
Last edited by Chris_in_the_UK on Sun Jul 30, 2017 8:47 pm; edited 1 time in total
Stuart Mackay
PostPosted: Tue May 30, 2017 11:20 pm    Post subject: Reply with quote
Me too please
2007 Speed Yellow 997 Carrera GT3 CS
2002 Guards Red Aerokit 996.2 C4S Cabriolet
2000 Westfield Cosworth
MikeWhite
PostPosted: Sun Jun 04, 2017 3:40 pm    Post subject: Reply with quote
Boxster 987 3.2S 2005 if possible
Mike
Jamesyg
PostPosted: Fri Jul 28, 2017 9:42 am    Post subject: Reply with quote
Me please... 996 turbo
‘84 73 RS Recreation
‘83 911 SC
‘79 1500 MG Midget
P911X50
PostPosted: Fri Jul 28, 2017 5:05 pm    Post subject: Reply with quote
Hi
I would like 996 GT3.2 caliper studs plz thumbsup
Porsche 996 Turbo X50 with 9e exhaust,
BMW M6 V10,
Previous
Evo 4 with Evo 8 MR Engine 360 bhp - Road Legal Track car
Previous
MR2 Turbo 280 bhp - Road Legal Track Car
L8ydg
2003 Porsche 996 Carrera 4S
PostPosted: Fri Jul 28, 2017 5:17 pm    Post subject: Reply with quote
Me please 996 4s (red turbo calipers)
Pickse
PostPosted: Sat Jul 29, 2017 12:07 pm    Post subject: Reply with quote
Me please. 996 Turbo 4 pot callipers
Pickse
03 Arctic Silver 996T Tip S
Now 9E38 - An improved! 996T
FRP
PostPosted: Sun Jul 30, 2017 4:56 pm    Post subject: Reply with quote
i would be interested,,,,,tbh i don't know what callipers i have now on my car,,,,6 pot motorsport items at a best guess ? How do i find out ?
2002 996tt x50 manual in bassat black - 9eXX
Nik
PostPosted: Tue Aug 01, 2017 6:21 pm    Post subject: Reply with quote
Would be interested for a 993 C2 and a 997.2 C2S, subject to getting more clarity on cost.
ok51mon
PostPosted: Tue Aug 01, 2017 6:43 pm    Post subject: Reply with quote
Me Please 996 turbo
G3BML
PostPosted: Tue Aug 08, 2017 9:12 pm    Post subject: Reply with quote
Any news on these? I'd be interested in a set of a 996 C4S
2003 Guards Red 996 Carrera 4S
Nik
PostPosted: Tue Aug 08, 2017 10:55 pm    Post subject: Reply with quote
Are they relevant for a 993 too ?
ok51mon
PostPosted: Wed Aug 09, 2017 6:34 am    Post subject: Reply with quote
Interested
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Wed Aug 09, 2017 9:52 am    Post subject: Reply with quote
Definitely very interested thumbsup
Stoo.c
PostPosted: Thu Aug 10, 2017 8:26 am    Post subject: Reply with quote
Yep 996 4s (turbo red calipers) for me as well.
02 996 C4S
93 Skyline R33 GTS-t
91 CRX vtec turbo
01 986 Boxster S
Marky911
PostPosted: Fri Aug 11, 2017 12:07 am    Post subject: Reply with quote
Interested.
996.1 C2, full car set please.
Thanks.
996lee
PostPosted: Fri Aug 11, 2017 8:32 am    Post subject: Reply with quote
Don't suppose you've considered making ti wheel nuts?
2001 Carrera 4 aero all the way!!
poppopbangbang
PostPosted: Mon Sep 11, 2017 11:39 am    Post subject: Reply with quote
Hi All,
The first set of these has now completed DT and FEA as it was looking like it was a bit more than just the one set required - the powers that be insist these are marked "Motorsport Use Only" (because anything brakes + insurer = Surprised) but I can confirm they yield at 2.2 times the load of the original fastener which itself has a factor of safety built in.
I have two sets here (destroyed one in testing) to the original specification for PCCB mounting. For 996 Turbo and C2/C4/Boxster/Cayman I will need to draw up a new design with the lengths reduced accordingly as I believe there will be some combinations that foul the wheel if running 17" rims with the smaller 4 pot brakes and longer stud.
I expect to have an option for all those that want some in around 4 weeks. In the meantime the two sets of PCCB ones are available now Smile PM if interested.
