991 : 2011- 19
997 : 2004- 74
996 : 1997-2005 33
993 : 1993-1998 7
Boxster : 1997- 33
Cayman : 2005- 20
glazey
PostPosted: Wed May 24, 2017 10:00 pm    Post subject: Ball joint removal tool Reply with quote
Anyone know which ball joint splitter fits the ball joint on the control arm.
I am wanting to replace a broken spring on my 997 4s. And need to remove the ball joint from the shock.
In the Porsche workshop manual it says use the special press-out tool 9560 but i can't find any information on it.
I was thinking of getting a Franklin TA330
Any advice would be appreciated
Tom
Frenchmeister
2004 Porsche 997 Carrera 2S
PostPosted: Wed May 24, 2017 10:07 pm    Post subject: Reply with quote
Try your main dealer they should be able to sell you one the tools are usually fairly priced.
997 Carrera 2S 54 Arctic Silver
944 Turbo S 88 Solid Black
BMW X3 2.0D M Sport 06 Silver Grey
BMW E46 330i touring M Sport 05 Imola Red 2
DucatiRob
PostPosted: Thu May 25, 2017 9:46 am    Post subject: Reply with quote
You should be able to get one from Halfords, most are fairly universal!
Mercedes CLK DD
Ducati 996
ELA
PostPosted: Thu May 25, 2017 10:13 am    Post subject: Reply with quote
Use the piano fork type with hammer; the universal threaded ones I have bought (3 of) wont fit. Obviously this method can cause damage to the rubber so only go this way if you are replacing rather than inspecting.
OEM Porsche is a good call but can only imagine the prices
CLR996 1086kg bespoke design
glazey
PostPosted: Thu May 25, 2017 12:24 pm    Post subject: Reply with quote
Thanks for your help.
The oem one was $240 so I've ordered a universal one, like this:
http://www.ebay.co.uk/itm/Ball-Joint-Separator-Splitter-20-50mm-Tie-Rod-End-Lifter-Scissor-New-Garage-1556-/131972380765?hash=item1eba2ab85d:g:FpcAAOSwPCVYA6PA
I will see if it fits. If i cant get it off i will order a new ball joint at force it off with the fork style
Has anyone taken off a PASM shock front shock?
Tom
PostPosted: Thu May 25, 2017 6:35 pm    Post subject: Reply with quote
The one you have ordered will work just fine .. its similar to the snap on one i have .. when useing spray the rubber boot with wd40 or similar then its kinda normal to use a hammer to get the tool far enough in .
Yep ive removed pasm shocks , is there a particular question ?
You will need either a 21 or 22mm socket with a slot in it for the wire to undo the top nut and youll need to hold the top washer to make sure the shaft doesnt turn .. water pump pliers will do although there is a special tool for it .. a VW tool lol .
steve r
PostPosted: Thu May 25, 2017 6:42 pm    Post subject: Reply with quote
Demort wrote:
The one you have ordered will work just fine .. its similar to the snap on one i have .. .
Do you know the part number of the Snap On one?
40th Anniversary
PostPosted: Thu May 25, 2017 6:48 pm    Post subject: Reply with quote
Nope .. im afraid i just walked on his van and bought it .. ill have a look at it tomorrow and see if theres any numbers on it .. but it looks very similar to the one on ebay .
steve r
PostPosted: Thu May 25, 2017 7:06 pm    Post subject: Reply with quote
Thanks, the jaws on the one I have weren't quite wide enough, I've ground a bit out but they're still not quite right.
40th Anniversary
steve r
PostPosted: Thu May 25, 2017 7:18 pm    Post subject: Reply with quote
A spot of googling suggests the OEM tool is made by Nexus, part number 169-1p. Jaw width of 24mm
Edit: that info was from an old forum post, might need to drop the P from the part number now:
http://www.nexus.de/wp-content/uploads/2016/02/Nexus_Katalog_2016_Screen_79.pdf
40th Anniversary
steve r
PostPosted: Thu May 25, 2017 7:41 pm    Post subject: Reply with quote
Also made by Heni?
https://shop.heni-werkzeuge.de/shop/product/heni-32-109/abzieher-fuer-kugelgelenke-20-mm-gabeloeffnung-169-1/
40th Anniversary
PostPosted: Thu May 25, 2017 8:14 pm    Post subject: Reply with quote
The image on the left looks like what i have .. one on the right looks huge .. more of a truck one lol .
steve r
PostPosted: Thu May 25, 2017 8:47 pm    Post subject: Reply with quote
Yep, the one on the right looks too big with the added spacer section. I think the key dimension is the 24mm jaw width. Can you measure your snap on one?
40th Anniversary
pooga
PostPosted: Thu May 25, 2017 9:17 pm    Post subject: Reply with quote
This one fits 996 C4S - KS Tools 700.561 Ball Joint Separator, 0-55mm £54 on Amazon.
steve r
PostPosted: Thu May 25, 2017 9:46 pm    Post subject: Reply with quote
Thanks, looks very similar to the others and appears to have the same 24mm jaw width.
http://www.ksportal.de/en/hand-tools-catalogue/pullers/windscreen-wiper-arm-puller/ball-joint-separator-0-55mm
40th Anniversary
glazey
PostPosted: Fri May 26, 2017 7:10 am    Post subject: Reply with quote
Thanks for the info. unfortunately mine has a 19mm fork width. Hopefully i can open it out enough with a grinder.
PostPosted: Fri May 26, 2017 5:50 pm    Post subject: Reply with quote
Ok the snap on one i have is actually a bluepoint ..
Part number ITC001BJC , it has a jaw width of 25 mm , might have been 24 but its seen a lot of use Very Happy
glazey
PostPosted: Fri May 26, 2017 9:16 pm    Post subject: Reply with quote
Hi Demort,
Have you ever changed a front strut on a C4S. Just started taking it off. Everything is really tight.
It looks like you need to remove the driveshaft hub nut, do you need to remove the whole hub??
steve r
PostPosted: Fri May 26, 2017 10:29 pm    Post subject: Reply with quote
Thanks, I'll see what my local Snap On man can do.
40th Anniversary
PostPosted: Sat May 27, 2017 2:45 pm    Post subject: Reply with quote
glazey wrote:
Hi Demort,
If changeing the shock then you would undo the hub nut , remove all fixings other than the top stut then pull out the hub so its off the driveshaft then slide it down and off of the shock .. or just remove the whole lot in one go .. guide here for a non C4 ..
Guide does show another method although thats not the way i would do it .. far too close to the wing that way and a pain to get the suspension low enough .
https://rennlist.com/how-tos/a/porsche-997-how-to-replace-front-shocks-386604
http://www.pelicanparts.com/techarticles/Porsche-996-997-Carrera/63-SUSPEN-Replacing_Shocks_and_Springs/63-SUSPEN-Replacing_Shocks_and_Springs.htm
