Good morning all,
My car will soon be going in for a minor service and some preventative maintenance, I have a few questions on sourcing of fluids / parts....
Oil
I believe hartech recommend Millers nanodrive 10w/50?
Any recommendations for magnetic sump plugs?
LTT + Coolant
Which LTT is considered the best?
Design911 are fairly local so could pick this one up...
http://www.design911.co.uk/fu/prod7...orsche-986-Boxster---996---987-Boxster---997/
In theory the coolant is fit for life, however coolant will be lost when fitting the LTT, is the general concensous just top fill back up or flush the system and replace all of the coolant?
If replacing all of the coolant is there any preference on which coolant to use? It would be very expensive to replace all of the coolant with Porsche coolant straight from the main dealer. 32 Litres is a shed load of coolant!
There is also chirping noise which appears to be linked to rotational speed of the belt, I think this is the water pump. Any recommendations for which pump to use? The Porsche OEM pump is significantly more expensive compared with non-OEM.
Thank you in advance!
Oil
LTT + Coolant
