..at last! Had these a while and got around to fitting them today! Easy job as the engine has been removed recently so nuts and bolts were not a problem. Took about an hour including cleaning bits and pieces.
First impressions.....brilliant! Very little movement from the engine on start-up. I have used the yellow inserts that are the softest of the three choices. There doesn't appear to be any more vibration than I had with the standard mounts throughout the rev range which is a pleasant surprise and hardly noticeable at idle. Everything feels a little bit tighter now, the rear end feels more stable and gear change slicker and more precise.
There is certainly slightly more noise transmitted to the cabin but only a little and it is more of a pleasant mechanical noise and not harsh at all. The exhaust tips now sit nice and tight to the body, probably lifted the engine up by a good half inch or so compared to the old mounts.
Overall very happy with them :thumb:
