So, a few weeks ago I posted that I had bought an OE front Aero PU. Now had it fitted a couple of weeks and finally got around to taking some pictures. I really love it, yes it hits the ground quite a bit (I also have lowered springs) but I have also fitted a rubber trim strip which I bought from a site in the USA (found on rennlist). It doesnt stop it hitting but it does help prevent the white showing through and I think it looks pretty good as well.
I have tried a few number plate options but gone with a bracket that bolts to the underside of the PU which is adjusted so the plate is just in front of the PU also, you cannot see the bracket unless you really look 8)
